Bonjour la comu
J'en suis à ma premiere impression pour regler le z offset. J'utilise orcaslicer et klipper. Dés le lancement de mon impression et après un retour à home j'ai le message d'erreur suivant qui s'affiche :
Move exceeds maximum extrusion (1.002mm^2 vs 0.640mm^2)
Je pense que le probleme se situe dans mon gcode de démarrage puisqu'il ne se réalise pas complétement
G90 ;Use absolute coordinates
M83 ;Extruder relative mode
M104 S[first_layer_temperature] ;Set extruder temp
M140 S[first_layer_bed_temperature] ;Set bed temp
M190 S[first_layer_bed_temperature] ;Wait for bed temp
M109 S[first_layer_temperature] ;Wait for extruder temp
G28 ;Move X/Y/Z to min endstops
G1 Z0.28 ;Lift nozzle a bit
G92 E0 ;Specify current extruder position as zero
G1 Y3 F1800 ;Move Y to purge point
G1 X60 E25 F500 ;Extrude 25mm of filament in a 5cm line
G92 E0 ;Zero the extruded length again
G1 E-2 F500 ;Retract a little
G1 X70 F4000 ;Quickly wipe away from the filament line
M117
et voici mon config.cfg
[stepper_x]
step_pin: PA12
dir_pin: PA11
enable_pin: !PA15
microsteps: 16
rotation_distance: 40
endstop_pin: !PH2
position_endstop: -13
position_min:-13
position_max: 236
homing_speed: 50
[stepper_y]
step_pin: PA9
dir_pin: PA8
enable_pin: !PA15
microsteps: 16
endstop_pin: ^!PC13
position_endstop: -9
position_min:-9
position_max: 230
homing_speed: 50
[stepper_z]
step_pin: PC7
dir_pin: !PC6
enable_pin: !PA15
microsteps: 16
rotation_distance: 8
endstop_pin: ^PC14
#position_endstop: 0
position_min: -10
position_max: 255
homing_speed: 5
[extruder]
step_pin: PB15
dir_pin: !PB14
enable_pin: !PA15
microsteps: 16
rotation_distance: 31.07
max_extrude_only_velocity: 25
max_extrude_only_accel: 1000
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PB8
sensor_type: ATC Semitec 104GT-2
sensor_pin: PC3
min_extrude_temp: 170
min_temp: 0
max_temp: 250
#control: pid
#pid_kp: 19.56
#pid_ki: 1.62
#pid_kd: 200.00
[heater_bed]
heater_pin: PB9
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PC1
min_temp: 0
max_temp: 120
#control: pid
#pid_kp: 97.1
#pid_ki: 1.41
#pid_kd: 1675.16
[bed_mesh]
speed: 200
horizontal_move_z: 2.5
mesh_min: 34, 34
mesh_max: 200, 200
probe_count: 5, 5
[probe]
pin: PA1
x_offset: 33
y_offset: 0
#z_offset: 0
samples: 3
samples_result: average
samples_tolerance_retries: 3
sample_retract_dist: 0.5
speed: 2
lift_speed: 4
[safe_z_home]
home_xy_position: 0, 0
speed: 5
z_hop: 10
z_hop_speed: 15
[controller_fan controller_fan]
pin: PB12
[heater_fan extruder_fan]
pin: PB13
[fan]
pin: PB5
cycle_time: 0.00005 #20kHz
[output_pin enable_pin]
pin: PB6
static_value: 1
    #This pin enables the bed, hotend, extruder fan, part fan.
[mcu]
serial: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 500
max_z_velocity: 4
max_z_accel: 100
#*# <---------------------- SAVE_CONFIG ---------------------->
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
#*# [extruder]
#*# control = pid
#*# pid_kp = 22.618
#*# pid_ki = 1.012
#*# pid_kd = 126.379
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 62.646
#*# pid_ki = 1.108
#*# pid_kd = 885.662
#*# [probe]
#*# z_offset = 0.051
#*# [stepper_z]
#*# position_endstop = 5.158
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*#       -0.384667, -0.381333, -0.384667, -0.398833, -0.343833
#*#       -0.313833, -0.293000, -0.287167, -0.286333, -0.269667
#*#       -0.372167, -0.322167, -0.308000, -0.277167, -0.233833
#*#       -0.330500, -0.330500, -0.309667, -0.282167, -0.228833
#*#       -0.351333, -0.332167, -0.307167, -0.283833, -0.220500
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 34.0
#*# max_x = 200.0
#*# min_y = 34.0
#*# max_y = 200.0
Bonsoir @cybernino
J'ai déjà eu ce problème :
Dans ton config.cfg
dans la section extrudeur
tu rajoutes le ligne
max_extrude_cross_section: 2
Lorsque ce n'est pas précisé la valeur par défaut est 0.640
avec 2 tu passeras.
filament_diameter: # Diamètre moyen du filament (en mm) lorsqu'il entre dans l'extrudeuse. # Ce paramètre doit être fourni. #max_extrude_cross_section: # Surface maximale (en mm^2) d'une section transversale d'extrusion (ex: # largeur de l'extrusion multipliée par la hauteur de la couche). Ce paramètre # permet d'éviter d'extruder des quantités excessives durant de petits déplacements # XY. Si un déplacement demande une quantité d'extrusion supérieure à cette valeur, # une erreur sera renvoyée. La valeur par défaut est 4.0 *diamètre_buse^2
https://www.klipper3d.org/fr/Config_Reference.html?h=extrude#extruder
