Gærbek Posté(e) mardi à 07:37 Posté(e) mardi à 07:37 Bonjour, je partage un lien vers une recette trouvée dans le FB de Elegoo. Pas encore testée... Bon appétit https://www.facebook.com/groups/elegoocentauri/permalink/1482610916139830/
PPAC Posté(e) mardi à 10:38 Posté(e) mardi à 10:38 (modifié) Il y a 3 heures, Gærbek a dit : https://www.facebook.com/groups/elegoocentauri/permalink/1482610916139830/ Citation The "Magic Potion" Recipe 1. 10 oz of Isopropyl Alcohol (70%): This strength is the sweet spot! I recommend avoiding weaker mixtures. Note: If you only have 91% or 99% on hand, just dilute it with a little distilled water. 2. 6g of Glue Stick: I personally love the Elmer’s Purple Glue Stick. The tint helps you see where you've applied it, plus it dries clear! That said, any generic washable glue stick will get the job done. 3. A Spray Bottle (12oz+): Clean and empty. How to Mix It: Slice off about 6g of the glue (roughly one standard small stick) and drop it into your spray bottle. Pour in the alcohol and give it a shake. Important Patience Tip: Alcohol doesn't dissolve glue instantly, so don't panic! Let the mixture soak for 12-24 hours to fully incorporate. Once it’s dissolved, give it one last shake, and you're ready to go. How to Apply: For the sake of your printer's fans and vents, please do not spray this directly into the machine. Aerosolized glue can get sucked into sensitive areas. Instead, simply spritz a little onto a clean microfiber cloth or paper towel, then wipe down your build surface. This creates a thin, strong adhesive layer and cleans your bed at the same time! I think you'll be just as impressed as I was. Happy Printing, Fellow Tinkerers! Pourquoi pas ... pour moi c'est l'équivalent ( mais sous forme liquide à pulvériser car dilué dans de l'IPA ) d'un bâton de colle type UHU Mais donc, attention lors de l'application, quand on le pulvérise, de ne pas en mettre sur les rails ou tiges lisses ou filetées. Modifié (le) mardi à 10:41 par PPAC 1
pascal_lb Posté(e) mardi à 14:49 Posté(e) mardi à 14:49 Il y a 4 heures, PPAC a dit : attention lors de l'application, quand on le pulvérise, de ne pas en mettre sur les rails ou tiges lisses ou filetées Il y a ça mais en plus ça donne quoi les vapeurs d'IPA quand ça chauffe ? il faut maintenant porter un masque à cartouche pour imprimer 1
Gærbek Posté(e) mardi à 18:37 Auteur Posté(e) mardi à 18:37 (modifié) J'ai réalisé la mixture... Y a plus qu'à attendre que la colle fonde, là j'ai un doute (12h, 24h, jamais ?) Précautions élémentaires pour tout spray composé d'alcools ou d'éthers (comme les laques pour cheveux, et spray de colles prêtes à l'emploi des boutiques habituelles) : à tenir éloigné de toutes flammes ou sources de chaleur (dixit notices...). Donc (si la colle a fondu), je vais sortir la plaque d'impression de l'imprimante, vaporiser, attendre que ça sèche (l'IPA ça va vite en général), puis replacer la plaque, avant d'imprimer. Je vous tiens au jus Modifié (le) mardi à 18:38 par Gærbek 1
Gærbek Posté(e) mardi à 18:43 Auteur Posté(e) mardi à 18:43 (modifié) Bah, j'ai des gants et un tablier de labo, des masques et je ferai ça sous la hotte de la cuisine ... et je prendrai garde à ne pas être "à côté de la plaque" Modifié (le) mardi à 18:44 par Gærbek 3
Savate Posté(e) mercredi à 07:40 Posté(e) mercredi à 07:40 Le 16/12/2025 at 08:37, Gærbek a dit : Bonjour, je partage un lien vers une recette trouvée dans le FB de Elegoo. Pas encore testée... oui, mais ça sert à quoi ? parce que avec les plateaux modernes, les problèmes d'accroche ne sont plus vraiment des problèmes. 2
Gærbek Posté(e) mercredi à 18:59 Auteur Posté(e) mercredi à 18:59 Avec la CC, Elegoo livre un bâton de colle dans la dotation d'outillage ; il m'a bien aidé quand mon PETG a commencé à warper. Pourtant c'est un plateau PEI. A l'heure qu'il est, les morceaux de bâton (Elegoo) ne sont pas encore complètement dissous... Je testerai demain.
Gærbek Posté(e) jeudi à 12:14 Auteur Posté(e) jeudi à 12:14 Il a fallut 36 h pour tout dissoudre (pas au point la recette ). Dommage que je n'ai pas pu l'utiliser hier soir : j'ai lancé une impression bicolore de 20 h sur ma Kobra S1, ce matin j'ai trouvé la tour de purge renversée et le capot de la tête (où il y a le ventilo de refroidissement des couches), vautré sur le plateau. Un peu de "chewing gum" sur la buse mais il s'est détaché tout seul ; la S1 s'est très vite arrêtée apparemment... Donc, j'ai relancé l'impression avec ce fameux "jus magique". Il faut un peu de temps pour que ça sèche, l'odeur d'alcool est partie en 30'' mais il restait un film humide. J'en ai conclu que c'était l'eau distillée, alors j'ai remis la plaque en place et monté la température du bed + le ventilateur auxiliaire. La trace d'humidité a disparu comme neige au soleil. Verdict dans 20 heures ! 1
Savate Posté(e) jeudi à 12:22 Posté(e) jeudi à 12:22 Il y a 17 heures, Gærbek a dit : mon PETG a commencé à warper pourtant le petg est connu pour coller au pei comme une arapède à son rocher. 1
Gærbek Posté(e) jeudi à 12:30 Auteur Posté(e) jeudi à 12:30 (modifié) il y a 9 minutes, Savate a dit : une arapède ça se mange ? Moi, ce qui tient bien sur mes plaques c'est le TPU. J'ai même arraché le revêtement d'un PEI en insistant trop fort pour retirer la pièce. Depuis j'ai trouvé un truc (je ne sais plus où) : je passe le tout au congélateur pendant une demi-heure Modifié (le) jeudi à 12:31 par Gærbek
Savate Posté(e) jeudi à 12:44 Posté(e) jeudi à 12:44 il y a 14 minutes, Gærbek a dit : ça se mange ? oui 1
KpDp_3D Posté(e) jeudi à 13:46 Posté(e) jeudi à 13:46 @Gærbek (pas facile le ae collé à taper lol) Pour le TPU qui colle en effet fort, je mets du scotch bleu 3M pour protéger le PEI. Le TPU adhère bien au scotch et s'enlève sans soucis 1
Gærbek Posté(e) jeudi à 18:44 Auteur Posté(e) jeudi à 18:44 @KpDp_3D merci pour l'astuce Je te renvoie l’ascenseur : pour "taper" le æ, j'ouvre la "Table de caractères" de Windows et je fais un copier-coller 1
fran6p Posté(e) il y a 12 heures Posté(e) il y a 12 heures Avec mon clavier AZERTY norme Afnor, ATL GR+ a => æ 1
