GÊrbek Posté(e) Décembre 16 Posté(e) Décembre 16 Bonjour, je partage un lien vers une recette trouvée dans le FB de Elegoo. Pas encore testée... Bon appétit https://www.facebook.com/groups/elegoocentauri/permalink/1482610916139830/
PPAC PostĂ©(e) DĂ©cembre 16 PostĂ©(e) DĂ©cembre 16 (modifiĂ©) Il y a 3 heures, GĂŠrbek a dit : https://www.facebook.com/groups/elegoocentauri/permalink/1482610916139830/ Citation The "Magic Potion" Recipe  1. 10 oz of Isopropyl Alcohol (70%): This strength is the sweet spot! I recommend avoiding weaker mixtures. Note: If you only have 91% or 99% on hand, just dilute it with a little distilled water.  2. 6g of Glue Stick: I personally love the Elmerâs Purple Glue Stick. The tint helps you see where you've applied it, plus it dries clear! That said, any generic washable glue stick will get the job done.  3. A Spray Bottle (12oz+): Clean and empty.  How to Mix It:  Slice off about 6g of the glue (roughly one standard small stick) and drop it into your spray bottle. Pour in the alcohol and give it a shake. Important Patience Tip: Alcohol doesn't dissolve glue instantly, so don't panic! Let the mixture soak for 12-24 hours to fully incorporate. Once itâs dissolved, give it one last shake, and you're ready to go.  How to Apply:  For the sake of your printer's fans and vents, please do not spray this directly into the machine. Aerosolized glue can get sucked into sensitive areas. Instead, simply spritz a little onto a clean microfiber cloth or paper towel, then wipe down your build surface. This creates a thin, strong adhesive layer and cleans your bed at the same time!  I think you'll be just as impressed as I was. Happy Printing, Fellow Tinkerers! Pourquoi pas ... pour moi c'est l'Ă©quivalent ( mais sous forme liquide Ă pulvĂ©riser car diluĂ© dans de l'IPA ) d'un bĂąton de colle type UHU Mais donc, attention lors de l'application, quand on le pulvĂ©rise, de ne pas en mettre sur les rails ou tiges lisses ou filetĂ©es. ModifiĂ© (le) DĂ©cembre 16 par PPAC 1
pascal_lb Posté(e) Décembre 16 Posté(e) Décembre 16 Il y a 4 heures, PPAC a dit : attention lors de l'application, quand on le pulvérise, de ne pas en mettre sur les rails ou tiges lisses ou filetées Il y a ça mais en plus ça donne quoi les vapeurs d'IPA quand ça chauffe ? il faut maintenant porter un masque à cartouche pour imprimer 1
GĂŠrbek PostĂ©(e) DĂ©cembre 16 Auteur PostĂ©(e) DĂ©cembre 16 (modifiĂ©) J'ai rĂ©alisĂ© la mixture... Y a plus qu'Ă attendre que la colle fonde, lĂ j'ai un doute  (12h, 24h, jamais ?) PrĂ©cautions Ă©lĂ©mentaires pour tout spray composĂ© d'alcools ou d'Ă©thers (comme les laques pour cheveux, et spray de colles prĂȘtes Ă l'emploi des boutiques habituelles) : Ă tenir Ă©loignĂ© de toutes flammes ou sources de chaleur (dixit notices...). Donc (si la colle a fondu), je vais sortir la plaque d'impression de l'imprimante, vaporiser, attendre que ça sĂšche (l'IPA ça va vite en gĂ©nĂ©ral), puis replacer la plaque, avant d'imprimer. Je vous tiens au jus ModifiĂ© (le) DĂ©cembre 16 par GĂŠrbek 1
PPAC Posté(e) Décembre 16 Posté(e) Décembre 16 Prend garde de ne pas finir collé à la plaque   2
GĂŠrbek PostĂ©(e) DĂ©cembre 16 Auteur PostĂ©(e) DĂ©cembre 16 (modifiĂ©) Bah, j'ai des gants et un tablier de labo, des masques et je ferai ça sous la hotte de la cuisine ... et je prendrai garde Ă ne pas ĂȘtre "Ă cĂŽtĂ© de la plaque" ModifiĂ© (le) DĂ©cembre 16 par GĂŠrbek 3
Savate Posté(e) mercredi à 07:40 Posté(e) mercredi à 07:40 Le 16/12/2025 at 08:37, GÊrbek a dit : Bonjour, je partage un lien vers une recette trouvée dans le FB de Elegoo. Pas encore testée... oui, mais ça sert à quoi ? parce que avec les plateaux modernes, les problÚmes d'accroche ne sont plus vraiment des problÚmes. 2
GĂŠrbek PostĂ©(e) mercredi Ă 18:59 Auteur PostĂ©(e) mercredi Ă 18:59 Avec la CC, Elegoo livre un bĂąton de colle dans la dotation d'outillage ; il m'a bien aidĂ© quand mon PETG a commencĂ© Ă warper. Pourtant c'est un plateau PEI. A l'heure qu'il est, les morceaux de bĂąton (Elegoo) ne sont pas encore complĂštement dissous... Je testerai demain. Â
GĂŠrbek PostĂ©(e) jeudi Ă 12:14 Auteur PostĂ©(e) jeudi Ă 12:14 Il a fallut 36 h pour tout dissoudre (pas au point la recette ). Dommage que je n'ai pas pu l'utiliser hier soir : j'ai lancĂ© une impression bicolore de 20 h sur ma Kobra S1, ce matin j'ai trouvĂ© la tour de purge renversĂ©e et le capot de la tĂȘte (oĂč il y a le ventilo de refroidissement des couches), vautrĂ© sur le plateau. Un peu de "chewing gum" sur la buse mais il s'est dĂ©tachĂ© tout seul ; la S1 s'est trĂšs vite arrĂȘtĂ©e apparemment... Donc, j'ai relancĂ© l'impression avec ce fameux "jus magique". Il faut un peu de temps pour que ça sĂšche, l'odeur d'alcool est partie en 30'' mais il restait un film humide. J'en ai conclu que c'Ă©tait l'eau distillĂ©e, alors j'ai remis la plaque en place et montĂ© la tempĂ©rature du bed + le ventilateur auxiliaire. La trace d'humiditĂ© a disparu comme neige au soleil. Verdict dans 20 heures ! 1
Savate Posté(e) jeudi à 12:22 Posté(e) jeudi à 12:22 Il y a 17 heures, GÊrbek a dit : mon PETG a commencé à warper pourtant le petg est connu pour coller au pei comme une arapÚde à son rocher.  1
GĂŠrbek PostĂ©(e) jeudi Ă 12:30 Auteur PostĂ©(e) jeudi Ă 12:30 (modifiĂ©) il y a 9 minutes, Savate a dit : une arapĂšde  ça se mange ? Moi, ce qui tient bien sur mes plaques c'est le TPU. J'ai mĂȘme arrachĂ© le revĂȘtement d'un PEI en insistant trop fort pour retirer la piĂšce. Depuis j'ai trouvĂ© un truc (je ne sais plus oĂč) : je passe le tout au congĂ©lateur pendant une demi-heure ModifiĂ© (le) jeudi Ă 12:31 par GĂŠrbek
Savate Posté(e) jeudi à 12:44 Posté(e) jeudi à 12:44 il y a 14 minutes, GÊrbek a dit : ça se mange ? oui  1
KpDp_3D Posté(e) jeudi à 13:46 Posté(e) jeudi à 13:46 @GÊrbek (pas facile le ae collé à taper lol) Pour le TPU qui colle en effet fort, je mets du scotch bleu 3M pour protéger le PEI. Le TPU adhÚre bien au scotch et s'enlÚve sans soucis 1
GĂŠrbek PostĂ©(e) jeudi Ă 18:44 Auteur PostĂ©(e) jeudi Ă 18:44 @KpDp_3D merci pour l'astuce Je te renvoie lâascenseur : pour "taper" le Ê, j'ouvre la "Table de caractĂšres" de Windows et je fais un copier-coller 1
fran6p Posté(e) vendredi à 11:26 Posté(e) vendredi à 11:26 Avec mon clavier AZERTY norme Afnor, ATL GR+ a => Ê  1
GÊrbek Posté(e) il y a 6 heures Auteur Posté(e) il y a 6 heures (modifié) Le 19/12/2025 at 12:26, fran6p a dit : Avec mon clavier AZERTY norme Afnor, ATL GR+ a => Ê  Cela ne marche pas avec mon AZERTY .be ... La table de caractÚres de Windows est universelle, elle ! Mais on ne va pas en faire un fromage, d'autant que les fromages belges sont meilleurs que les français ... Je vais d'ailleurs, de ce pas, chez ma crémiÚre adorée , ne me cherchez pas ! Avant ça, j'oubliais : dans le rayon des recettes (pour celle en rubrique), ça marche à condition d'en "mettre un paquet" ; finalement c'est plus simple d'utiliser un bùton de colle. Il n'y a qu'un de mes essais qui m'a satisfait : avec du TPU, il s'est décollé gentiment, contrairement à son habitude. Donc je garde mon spray rien que pour lui ! Modifié (le) il y a 6 heures par GÊrbek 1
