bonjours a tous
j'ai un petit soucis pour installé marlin dans mon anet a8
voici le rapport qui saurais m'aider svp
je n'y connais rien en programmation ni en anglais 😋
merci
Arduino : 1.8.13 (Windows 10), Carte : "Anet V1.0"
In file included from sketch\endstops.cpp:35:0:
sketch\endstop_interrupts.h: In function 'void setup_endstop_interrupts()':
endstop_interrupts.h:121:7: error: non-constant condition for static assertion
       static_assert(digitalPinToPCICR(X_MIN_PIN) != NULL, "X_MIN_PIN is not interrupt-capable");
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:258:0,
                 from sketch\HAL.h:36,
                 from sketch\MarlinConfig.h:39,
                 from sketch\Marlin.h:35,
                 from sketch\endstops.cpp:27:
C:\Program Files (x86)\Arduino\hardware\anet\avr\variants\sanguino/pins_arduino.h:117:66: error: reinterpret_cast from integer to pointer
 #define digitalPinToPCICR(p)    ( (((p) >= 0) && ((p) <= 31)) ? (&PCICR) : ((uint8_t *)0) )
sketch\endstop_interrupts.h:121:21: note: in expansion of macro 'digitalPinToPCICR'
endstop_interrupts.h:141:7: error: non-constant condition for static assertion
       static_assert(digitalPinToPCICR(Y_MIN_PIN) != NULL, "Y_MIN_PIN is not interrupt-capable");
sketch\endstop_interrupts.h:141:21: note: in expansion of macro 'digitalPinToPCICR'
endstop_interrupts.h:161:7: error: non-constant condition for static assertion
       static_assert(digitalPinToPCICR(Z_MIN_PIN) != NULL, "Z_MIN_PIN is not interrupt-capable");
sketch\endstop_interrupts.h:161:21: note: in expansion of macro 'digitalPinToPCICR'
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Modifié (le) par sarsarote
merci ca a compilé puis ma mis ca
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\polia\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\polia\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\polia\OneDrive\Documents\Arduino\libraries -fqbn=anet:avr:anet -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\polia\AppData\Local\Temp\arduino_build_665957 -warnings=none -build-cache C:\Users\polia\AppData\Local\Temp\arduino_cache_990385 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\polia\OneDrive\Bureau\Marlin-1.1.x\Marlin\Marlin.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\polia\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\polia\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\polia\OneDrive\Documents\Arduino\libraries -fqbn=anet:avr:anet -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\polia\AppData\Local\Temp\arduino_build_665957 -warnings=none -build-cache C:\Users\polia\AppData\Local\Temp\arduino_cache_990385 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\polia\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\polia\OneDrive\Bureau\Marlin-1.1.x\Marlin\Marlin.ino
Using board 'anet' from platform in folder: C:\Program Files (x86)\Arduino\hardware\anet\avr
Using core 'arduino' from platform in folder: C:\Users\polia\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23
Detecting libraries used...
"C:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR "-IC:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.23\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\anet\\avr\\variants\\sanguino" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Marlin.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\G26_Mesh_Validation_Tool.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\I2CPositionEncoder.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\M100_Free_Mem_Chk.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\MarlinSerial.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\Marlin_main.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\Max7219_Debug_LEDs.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\Sd2Card.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdBaseFile.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdFatUtil.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdFile.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdVolume.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\blinkm.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\cardreader.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\configuration_store.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\dac_mcp4728.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\digipot_mcp4018.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\digipot_mcp4451.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\emergency_parser.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\endstops.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\fwretract.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\hex_print_routines.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\least_squares_fit.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\leds.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\malyanlcd.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\mesh_bed_leveling.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\neopixel.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\nozzle.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\parser.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\pca9632.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\planner.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\planner_bezier.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\power.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\power_loss_recovery.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\printcounter.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\runout.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\serial.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\servo.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stepper.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stepper_dac.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stepper_indirection.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stopwatch.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\temperature.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\tmc_util.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\twibus.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ubl.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ubl_G29.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ubl_motion.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ultralcd.cpp
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
  -> candidates: [LiquidCrystal@1.0.7]
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\utility.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\vector_3.cpp
Using cached library dependencies for file: C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\watchdog.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src\LiquidCrystal.cpp
Generating function prototypes...
"C:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR "-IC:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.23\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\anet\\avr\\variants\\sanguino" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Marlin.ino.cpp" -o "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compilation du croquis...
"C:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR "-IC:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.23\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\anet\\avr\\variants\\sanguino" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Marlin.ino.cpp" -o "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Marlin.ino.cpp.o"
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\M100_Free_Mem_Chk.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\I2CPositionEncoder.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\Sd2Card.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\MarlinSerial.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\Max7219_Debug_LEDs.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\G26_Mesh_Validation_Tool.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdBaseFile.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\Marlin_main.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdFile.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdFatUtil.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\blinkm.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\cardreader.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\digipot_mcp4018.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\SdVolume.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\dac_mcp4728.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\configuration_store.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\emergency_parser.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\digipot_mcp4451.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\fwretract.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\endstops.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\malyanlcd.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\hex_print_routines.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\mesh_bed_leveling.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\leds.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\least_squares_fit.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\neopixel.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\nozzle.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\parser.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\power.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\planner.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\power_loss_recovery.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\pca9632.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\planner_bezier.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\runout.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\printcounter.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\serial.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\servo.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stepper_dac.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stepper.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stopwatch.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\temperature.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\stepper_indirection.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\tmc_util.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ubl.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\twibus.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ubl_G29.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ubl_motion.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\vector_3.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\utility.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\watchdog.cpp.o
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\sketch\ultralcd.cpp.o
Compiling libraries...
Compiling library "LiquidCrystal"
Utilisation du fichier déjà compilé : C:\Users\polia\AppData\Local\Temp\arduino_build_665957\libraries\LiquidCrystal\LiquidCrystal.cpp.o
Compiling core...
Using precompiled core: C:\Users\polia\AppData\Local\Temp\arduino_cache_990385\core\core_anet_avr_anet_bb2f033e31c7054cc9d9c26531160950.a
Linking everything together...
"C:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega1284p -o "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957/Marlin.ino.elf" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\G26_Mesh_Validation_Tool.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\I2CPositionEncoder.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\M100_Free_Mem_Chk.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Marlin.ino.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\MarlinSerial.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Marlin_main.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Max7219_Debug_LEDs.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\Sd2Card.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\SdBaseFile.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\SdFatUtil.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\SdFile.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\SdVolume.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\blinkm.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\cardreader.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\configuration_store.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\dac_mcp4728.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\digipot_mcp4018.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\digipot_mcp4451.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\emergency_parser.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\endstops.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\fwretract.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\hex_print_routines.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\least_squares_fit.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\leds.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\malyanlcd.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\mesh_bed_leveling.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\neopixel.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\nozzle.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\parser.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\pca9632.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\planner.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\planner_bezier.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\power.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\power_loss_recovery.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\printcounter.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\runout.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\serial.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\servo.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\stepper.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\stepper_dac.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\stepper_indirection.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\stopwatch.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\temperature.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\tmc_util.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\twibus.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\ubl.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\ubl_G29.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\ubl_motion.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\ultralcd.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\utility.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\vector_3.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\sketch\\watchdog.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957\\libraries\\LiquidCrystal\\LiquidCrystal.cpp.o" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957/..\\arduino_cache_990385\\core\\core_anet_avr_anet_bb2f033e31c7054cc9d9c26531160950.a" "-LC:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957" -lm
"C:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957/Marlin.ino.elf" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957/Marlin.ino.eep"
"C:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957/Marlin.ino.elf" "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957/Marlin.ino.hex"
Utilisation de la bibliothèque LiquidCrystal version 1.0.7 dans le dossier: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
"C:\\Users\\polia\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-size" -A "C:\\Users\\polia\\AppData\\Local\\Temp\\arduino_build_665957/Marlin.ino.elf"
Le croquis utilise 105770 octets (83%) de l'espace de stockage de programmes. Le maximum est de 126976 octets.
Les variables globales utilisent 4107 octets de mémoire dynamique.
Une erreur est survenue lors du transfert du croquis
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x9c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xba
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xee
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x21
Tu n'étais pas obligé de mettre tout le texte dans le message.
L'important ici c'est les dernières lignes : Arduino n'arrive pas à écrire dans ta carte.
Je ne connais pas Windows, je crois qu'il faut installer un driver (ch340, je crois). L'as-tu fait ?
As-tu choisi le bon port dans Arduino ?
Il faut également qu'il n'y ait pas d'autre application qui utiliserait ce port USB ( Cura, Pronterface...).
Modifié (le) par jmarie3D
j'ai installé ch340 Windows au moment de l'installation la carte c'est mise a clignoté et l'imprimante c'est relancé de la j'ai été sur repetier j'ai connecté l'imprimante et sa a mis connecté j'ai coupé repetier
puis sur arduino j'ai été dans outil - type de carte - marlin AVR boards - anet v1.0 j'ai eu le problème si dessus
j'ai essayé aussi avec anet v1.0 (optiboot) aussi et le même problème aussi
je ne comprend pas
Ton imprimante fonctionne avec l'ancien firmware, actuellement ? Ou elle est bloquée ?
Bon eh ho, on est pas à ton service, ici ! 😉
Tu es sûr que c'est dû aux steps ? C'est le firmware d'origine ?
À mon avis, une si grande erreur n'est pas due à un problème de configuration, mais plutôt à un problème matériel.
Tu as bien vérifié le montage ? Elle est récente ?  Elle a déjà fonctionné correctement ?
Si tu ne donnes pas plus de détail, on aura du mal à t'aider.
oui c'est firmware d'origine
elle est d'origine
problème de configuration mais ou tout fonctionnais parfaitement
c'est vrai j'ai voulu renforcé la rigidité avec du mdf que j'ai retiré quand j'ai vu le problèmes du cube
j'ai refait un cube et ca été le même
il y a 41 minutes, sarsarote a dit :
Nous y voilà !
L'Anet A8 a une structure fragile (c'est le moins qu'on puisse dire).  Il est risqué d'y toucher.
Sans voir "la bête", j'aurais du mal à faire un diagnostic. Est-ce que tu n'aurais pas distendu une courroie, foiré une poulie, ou autre ?
En tout cas, ce n'est pas en bidouillant le firmware que tu résoudras un problème matériel,  même si rien n'empêche d'installer Marlin (ce que j'ai fait).
les  courroies son bien tendues
quand l'impression démarre elle ne démarre pas au centre mais a 1/4 du plateau dans le coin droit
je n'arrive pas a téléversé marlin pour moi le mettre en Français et par après mettre le BLtouch que j'ai déjà mais pas encore monté
dans mes periférique port ( com et ltp ) usb-serial ch340 com4
voila se que sa me dit
Le croquis utilise 106022 octets (83%) de l'espace de stockage de programmes. Le maximum est de 126976 octets.
avrdude: ser_open(): can't open device "\\.\COM4": Acc�s refus�.
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
il y a 9 minutes, sarsarote a dit :
Encore autre chose...
Acc�s refus�.
Essaie en mode Administrateur.
Mais ça fait un moment que je n'ai pas touché à du Windows, alors ...
@Maeke une idée, peut-être ?
voici le raooprt arduino apres televerseent
j'avais instalé  AVRDUDESS-2.13-setup que j'ai desinstalé
voici le nouveau rapport
il y a 4 minutes, jmarie3D a dit :
Bah déjà vérifier dans le gestionnaire de périphériques que c'est bien com4.
Ensuite régler le logiciel de flashage et le gestionnaire de périphériques pour 115200 bps.
En gros windows n'arrive pas à communiquer avec le port parce que la vitesse de connection n'est pas bonne (et non, auto ça ne marche pas).
Modifié (le) par Maeke
Autres choses à vérifier, ne JAMAIS utiliser le câble usb fourni par Anet, C'EST UNE DAUBE INTERGALACTIQUE! (ultrasensible aux interférences électromagnétiques).
et s'assurer de sélectionner le bon type de bootloader à la compilation (ne coche optiboot que si tu AS installé le bootloader optiboot sur la carte (il ne peut pas être flashé en même temps, et pas par l'usb, il faut un usbasp ou un arduino).
Donc si tu n'as PAS flashé l'optiboot choisi Anet 1.0.
Si tu AS flashé optiboot, choisi Anet 1.0 (optiboot).
PS pour flasher optiboot il faut tout débrancher sur la carte sauf le programmeur (oui, alim comprise).
je vais instalé windows 7 sur un autre pc et refaire toute la manipulation et je reviens vers vous
je vien de lire ca
La plupart des derniers systèmes Windows 10 avec USB haute vitesse (USB3.0) ne parviennent pas à reconnaître le connecteur USB vers série (qui est ici: CH430).
Essayez avec un hub USB 2.0 auto-alimenté décent qui résout la majorité des problèmes de port USB 3.0, ou essayez de désactiver l'application de la signature du pilote sur Win10.
Foutaise, ça marche très bien avec mon windows 10. Ceci dit la plupart des pcs modernes ont ENCORE de l'usb 2.0.
bonjours tout démonté et remonté
j'ai fait le teste du cube et toujours le même résultat je comprend pas
il y bien un problème j'ai vérifier les 2 courroies mais rien ne change  toujours cube 20x25
je vais la foutre a la poubelle j'en peut plus
je fait le teste avec cura et repetier .
de plus je comprend pas avec repetier j'arrive manipulé mon imprimante avec les bouton du pc pour les axes et autre mais j'arrive pas a mettre marlin .
marlin ne reconnait pas mon imprimant et n'arrive pas a téléverser
Et quand tu déplaces la tête à l'aide des boutons, les dimensions sont respectées ou pas ?
L'erreur est dans quel sens ? X, Y Z ?
bonjour je sais plus dans comment était le cube je vais le refaire et faire une photo sur le plateau
ce que je me souvient c'est que le z était en haut pour moi c'est l'axe y qui a un problème
je comprend pas se que tu veut dire quand tu dit ( déplace la tète avec des bouton , les dimensions son respectée ) désolé je suis nouveau la dedans je comprend pas la démarche
Je te préviens que je n'ai pas beaucoup de patience avec les gens qui ne font pas un minimum d'efforts
C'est toi-même qui a utilisé l'expression "manipulé mon imprimante avec les bouton".
Je te demande donc si, quand tu demandes un déplacement de la tête de 100mm dans repetier, la tête se déplace réellement de 100mm.
C'est pourtant simple, non ?
