Bonjour a touts,
Depuis quelque jour Octoprint ne trouve plus mon imprimante, pourtant aucune MAJ n'a été effectuer, j ai tester avec un autre câble mais rien
connaissez vous ce problème ?
systeminfo:
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:95.0) Gecko/20100101 Firefox/95.0
connectivity.connection_check: 1.1.1.1:53
connectivity.connection_ok: True
connectivity.enabled: True
connectivity.online: True
connectivity.resolution_check: octoprint.org
connectivity.resolution_ok: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 915718144
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 3 Model B Plus Rev 1.3
env.plugins.pi_support.octopi_version: 0.18.0
env.plugins.pi_support.throttle_state: 0x0
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.safe_mode: False
octoprint.version: 1.7.2
systeminfo.generator: zipapi
Changing monitoring state from "Offline" to "Detecting serial connection"
Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
Trying port /dev/ttyUSB0, baudrate 115200
Connecting to port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x68df5bb0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Handshake attempt #2 with timeout 2.0s
Handshake attempt #3 with timeout 2.0s
Trying port /dev/ttyUSB0, baudrate 250000
Recv: 2ø6ø2ø6ø2ø2ø2ø>ø2ø6ø2ø6øñNàN\x976~m8.6Vr¶<ppH*\x08A\x8b\x90J5x%\x0c"|Q6Á25\x17\x12~\x9bp6\x92Hº@áB\x13\x13\x9fnð%Q\x98AEé]\x97'\x97ø%Yþ6ù}g\x97&Mð\x10_r69\x17\x12\x12ùB\x93\x1b6\x17zS.\x1bô%A7\x97(V\xff5\x94\x98\x17B\x82!\x10øaÁMh\x18\x17B¸k\x1aøeÁAhñApp\x0ee6\x1fP\x13:\x97P.l\x93tp\x10$\x10P\x10òvárÞ\x93H\x17X&fñJ8\x98B\x90(B\x880K\x9eB\xffÑ\x9e2\x17z4bP\x1fN\x17ðeÉ$p|\x10(\x1aú\x90I¸\x88A\x90%\x98\x00XBtt\x160>\x18á\x1bB:heÍbfñJ\x94Bä\x90I¸\x94I\x90%\x96J\xff\x88r\x14\x17r8i\x13oMX6Éj\x90Ka3.aCP\x93..iCKe\x9b*\x9bváB\x9cJð\x90I\x98!PJð\x90IvázX_a\x13Ú6á\x1fMc\x1fYÒ>A\x93"\x1bÜ6W*\x9bM\x8b&\x1bÖ@}\x93váJ\x9cZòB\x88A°z\x10O\x980\x923\x17rx\x93Ua:\x17B\x9cZ\x94A¨r\x10N\x98@árø\x7fzM´\x1b]váBØJ\x9a(\x9e2\x17B\x82!(\x18Brð\x14\x17B\x9a% %(\x86A\x9d\x08\x17B\x9a!8A0\x96A\x882\x17B\x82!(A0\x9eIz\x10\x17J\x9a% \x10Jjzý\x14\x17B\x9a% \x10Bjø\x88@ñJ\x92% \x10Jrjý\x14\x07B\x9a% \x08Bzx\x7fváJ\x9a% \x10Jrj\x7f2\x17B\x82!(\x18%rð\x10\x17J\x9a% %(frð\x14\x17B\x9a% A(fr\x94Jp|\x18\x13ð(A ~zø\x90HáB\x82!(\x18%rð\x88@ñJ\x92% \x10%rjý\x08\x17B\x9a!8\x18%z\x92Jtp\x10\x13ð(\x18%rð\x94@ñJ\x92% \x10%rt\x7f2\x17J\x92% \x10Jrh\x94HáJ\x92%(%$\x9eI­\x14\x07B\x9a% A(\x96A\x9d\x18\x17J\x92%(A$\x9eI
Bp|\x10\x13ø \x10Jjxý\x08\x17B\x9a%8\x18Bzp\x94HáJ\x92%(\x10Jrö\x88@áJ\x9a% \x10Jr\x8cBp|\x10\x13ø \x10Jj|\x7f2\x17J\x92% \x10Arv\x7f2\x17B\x9a%8%(\x96A}\x7fváB\x9a% A,\x86A\x94:\x07B\x9a% A(\x96Aö\x18\x17B\x82!(\x18Ar\x92Jpp\x08\x13ð(\x18Arð\x98@áB\x9a% \x10Ajz\x90XáB\x9a!8\x18Azrý\x18\x17J\x92%(\x10Ar\x8dJváB\x9a%8\x18Cz\x92Jtt\x10\x13ð8%0\x96A\x9d\x14\x07B\x9a% A,\x96AýBpt\x10\x17ø A,\x96Aö\x10\x17J\x92% \x10Kr\x96Bp|\x18\x13è \x10Krhý\x18\x17J\x92%(\x10Krö\x7f2\x17B\x82!(\x18Cr\x94Jpp\x08\x13ð(\x18Crt\x7f2\x17B\x9a%8\x18\x90z\x92Jtt\x10\x13ð8%0vrèBp|\x10\x13ø A(frðo:\x17B\x9a% A(frt\x7fváJ\x9a% \x10\x98rh\x7f2\x17B\x82!(\x18\x90rð\x98@áB\x9a% \x08\x90zz}\x10\x17J\x92% \x10\x98r\x94Bp|\x18\x13è \x10\x98r\x9do:\x07B\x9a% \x08CzøBpt\x10\x17ø %,\x96A\x942\x17B\x9a%8A,vr\x8aBp|\x18\x13è A,~rð\x7fváJ\x9a% \x10Kjz\x7f2\x17J\x92% \x10Kr\x94Bp|\x18\x13è \x10Krì\x88@ñJ\x92% \x10Kr¥\x7f2\x17B\x9a!8\x18Czmz\x14\x07B\x9a% \x18\x90XB\x8d:\x07B\x9a% %,vrö\x7f:\x07B\x9a% A,vr\x96Bp|\x18\x13è A,~zð\x98@áB\x9a% \x08\x90zøBpt\x10\x17ø \x08\x90z\x9aBtt\x10\x17ð8\x18\x90z\x92Jtt\x10\x13ð8\x18\x90zô\x7ffñJ\x92% \x10\x98r\x8dJváB\x9a% \x08BXR\x7f2\x17B\x9a%8%(vrjý\x08\x17B\x9a!8A8vr\x8aBp|\x10\x13ø A(frð\x7f2\x17B\x82!(\x18Brð\x88@ñJ\x92% \x10Jrj\x7f2\x17B\x9a!8\x18Bzrý\x18\x17J\x92%(\x10Jr\x8d\x90HáB\x82!(\x18Brm\x7f2\x17r8GñM\x17B*\x1b^váB¸K\x9a(J\x9eB|XB\x9aHáJ´C¾ Z\x96J|XB\x82@áJ¼[\x92 B\x8eBü!\x96J\x93\x17z0Aag\x97váJ¼Zð-°\x13\x96òX\]tp\x10$\x10þc²\x1bþ-ÞX%TºHár`\x17tyby\x172\x17JÔ-¾HázvRL^]\x13|<p|\x18è\x14þC\x94(\x96JR:fñz2A\x0bh6\}"|]PráJÔRø!\x90\x08-\x8e2\x17r:E\x1bP}Ciy:\x17BÜ-²ø6ù}~F\x1fø6ø.ø.øwait
WARNThe received line contains at least one null byte character at position 225, this hints at some data corruption going on
Recv: wait
Recv: wait
Trying port /dev/ttyUSB0, baudrate 230400
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Recv: wait
Trying port /dev/ttyUSB0, baudrate 57600
Trying port /dev/ttyUSB0, baudrate 38400
Trying port /dev/ttyUSB0, baudrate 19200
Trying port /dev/ttyUSB0, baudrate 9600
Changing monitoring state from "Detecting serial connection" to "Error"
Changing monitoring state from "Error" to "Offline after error"
Connection closed, closing down monitor
Modifié (le) par Gl0ux
Salutation !
Si tu connais le baudrate et le port a utiliser (qui fonctionnent) il semble préférable de les définir plutôt que de passer par l’auto détection ...
Vérifie que la connexion μUSB du câble sur le boitier est correcte 😉 (en gros, débranche / rebranche )
Bonjour, j'ai eu ce problème il y a quelques temps. Vérifie bien ton câble de liaison et ton dongle wifi, pour moi c'est le wifi qui ne faisait plus le boulot. Il est aussi possible que ce soit un addon qui foute le boxon, sinon réinstallation et tu règle le problème moins vite fait mais bien fait...
j'allais raire une Remise a Zéro, mais tout refonctionne !
Blizzard ! je comprend pas 🤷‍♂️
En tout cas merci beaucoup pour vos messages
