  Le 08/11/2023 at 14:33, RicoDarksky a dit :
pas que je sache mais je vais vérifier ^^
Dérouler
Donc en ayant regarder je n'est rien trouver d'anormal dans le fichier
bootlogo=true
overlay_prefix=sun50i-h616
## 'sun50i-h616-biqu-sd' for CB1, 'sun50i-h616-biqu-emmc' for CB1 eMMC version
fdtfile=sun50i-h616-biqu-sd
## default 'display' for debug, 'serial' for /dev/ttyS0
console=display
## Specify HDMI output resolution (eg. extraargs=video=HDMI-A-1:800x480-24@60)
#extraargs=video=HDMI-A-1:1024x600-24@60
## uncomment for ws2812
#overlays=ws2812
## uncomment for i2c-gpio, pwm3, disable uart0 for pwm3
#overlays=light
## uncomment for TFT35_SPI screen
#overlays=tft35_spi
## uncomment MCP2515 spi to canbus module
#overlays=mcp2515
## uncomment to release 'spidev0.0' to user space
#overlays=spidev0_0
## uncomment to release 'spidev1.0' to user space
#overlays=spidev1_0
## uncomment to release 'spidev1.1' to user space
#overlays=spidev1_1
## uncomment to release 'spidev1.2' to user space
#overlays=spidev1_2
## uncomment to set 'PH10' for IR
#overlays=ir
## write the config after the 'overlays' and separate it with a space when multiple functions are enabled
#overlays=disable_uart0 pwm ws2812 light tft35_spi mcp2515 spidev0_0 spidev1_0 spidev1_1 spidev1_2 ir
rootdev=UUID=680f8206-1a5c-4dd7-b39f-1229d5017302
rootfstype=ext4
Dérouler
du cote du fichier system non plu
check_interval=5        # Cycle to detect whether wifi is connected, time 5s
router_ip=8.8.8.8       # Reference DNS, used to detect network connections
eth=eth0        # Ethernet card device number
wlan=wlan0      # Wireless NIC device number
#hostname="BTT-CB1"
# System time zone setting, default Beijing time (East 😎
# More settable time zones can be viewed by running the command: timedatectl list-timezones
#TimeZone="Asia/Shanghai"
# HDMI klipperScreen rotation
# ks_angle: Rotation angle
#       normal: 0;          inverted: 180;
#       left: 90 to left;   right: 90 to right;
#ks_angle="normal"
# wifi name
WIFI_SSID=***********
# wifi password
WIFI_PASSWD=**********
WIFI_AP="false"             # Whether to open wifi AP mode, default off
WIFI_AP_SSID="rtl8189"      # Hotspot name created by wifi AP mode
WIFI_AP_PASSWD="12345678"   # wifi AP mode to create hotspot connection password
# BTT-PAD7 (ON/OFF)
BTT_PAD7="OFF"
# touch vibration effects
TOUCH_VIBRATION="OFF"
# touch sound effects
TOUCH_SOUND="OFF"
# Automatic brightness adjustment
AUTO_BRIGHTNESS="OFF"
Dérouler
PS *** c'est normal il y a bien le nom et le mot de passe de la wifi
Modifié (le) par RicoDarksky
bon, on a désormais la preuve que, même quand on est dans la mouise, l'aide du forum est efficace!
on arrive tjrs au bout du sujet, par itération!
