Concours #undertutu "under the hotend 3d group - Chitubox TUTU" imprimer et partager les photos de la mascote TUTU de Chitubox (se termine le 02/10/2022 - tirage au sort)
Salutation
Le groupe (public) Facebook "under the hotend 3d group" https://www.facebook.com/groups/1632161283639928/
organise avec le soutien de Chitubox un concours où il s'agit d'imprimer et de partager des photos de la mascotte Chitubox Tutu ( les gagnants seront tirés au sort )
Le post qui présente le concours
https://www.facebook.com/groups/1632161283639928/permalink/2049214588601260
Chitubox Give away
We are happy to bring another give away to our group, with the support of Chitubox
Its been a while since we ran one, so we thought it be a good time to do one as we just hit 1300 members.
So its simple to enter, all you need to do is head over to https://3duth.co.uk/products/chitubox-anniversary-model-tutu-boy download the file for free and print the Chitubox Tutu mascot out. Now this isn’t limited to just resin you could try printing it on a FDM printer if your brave enough.
Once you have printed the stl please post a photo on this post with #undertutu
Why not head over to the Chitubox Facebook group https://www.facebook.com/chitubox/ so you can be kept up to date with everything from them.
also Chitubox have a discrd channel go join up, they have give aways on there too https://discord.gg/PG6krWUQ
So this give away is aimed at UK and EU members only
So the prizes are as followed
5 winners of 1kg Conjure Resin
3 winners of nFEP film sets (3 feps in each set) 5.5 to 6 inch screen size
3 winners of 30 day Chitubox Pro licence
So a grand total of 11 prizes to be given out. The winners will be selected using a wheel of names.
Again as always a big thank you to all our members here, that help grow our own little community.
So closing date is the 02/10/22 and we will announce winners before 07/10/22
Please invite your friends to join in if they are not part of the group yet.
@Ironblue, @souriceaux  j'hésite a ressortir mes photos prisent lors de #Chituboxtutu 😉 https://www.lesimprimantes3d.fr/forum/topic/48365-chitubox-pro-1st-year-anniversary/
Edit : À noter que cette fois l'archive a télécharger (240.06 MB) comprend aussi une version découpée du modèle.
Bonne continuation a tous
il y a 24 minutes, Pyroa a dit :
Merci @PPAC pour l'info 😘
Moi je suis un ouf j'imprime en FDM ! 🙃
Résultat dans 17H 😱
De riens 🙂
En FDM 🤯 chapeau ! Car avec une imprimante résine cette figurine n'est pas facile a imprimer ( des éléments très fins et fragiles )  ...
j’espère que tu as aussi une imprimante résine ( ou que tu en auras bientôt une ) car les lots à gagner ne te seront pas vraiment utiles avec une FDM ...
Bonne impression !
orthographe...
Il y a 1 heure, PPAC a dit :
De riens 🙂
Bonne impression !
Oui c'est dans ma liste au père noel 😛 (qui ne contient que ca d'ailleurs )
[Edit] :
Des impressions que j'avais fait de figurines de 35mm de haut avec ma FDM :
Pas si mal non ? Elles sont brutes, non retravaillées, poncées etc. ...
Modifié (le) par Pyroa
  • J'aime 2
Le 23/09/2022 at 14:44, Pyroa a dit :
Ha oui là bien joué !
Sinon, j'ai partiellement triché ( mais chute 🙂 ) car j'ai réimprimé le fichier que j'avais préparé lors d'un précédent concours.
Cela m'a permis de voir ce que donne un mélange de "Anycubic Craftsman Resin White" + "SUNLU Standard Clear" + deux vieilles cartouches d'encre violette pour stylo à plume.
Résultat ... le mélange a le temps de sédimenter lors des ~10h d'impression et cela ne donne pas une couleur uniforme sur l'ensemble des couches. (j'ai probablement mis trop d'encre ou la Craftsman qui sédimente très vite est à éviter pour ce genre de mélange )
Malheureusement j'ai encore cassé la spatule quand j'ai enlevé le gros des supports ...
Le voici qui sèche après nettoyage a l'IPA
Edit : Demain, post traitement UV, enlever les derniers supports, petit ponçage, tentative de recollage de la spatule et rebouchage des ouvertures de drainage puis séance photo 🙂
Ajout : Et voila
image.thumb.jpeg.5c54251a09a3d3eab41052e335f58a31.jpeg image.thumb.jpeg.6d5593ee739de7b5d15feac45663b8ae.jpeg
Bonne chance à tous les participants et bonne continuation à tous.
  • J'aime 3
Je pense réutiliser celui que j'ai déjà imprimée en lui rajoutant une coupe de gagnant du premier concours, encore faut il avoir le temps de modéliser et d'imprimer une coupe...
Alors il s'est décollé une fois à 85% et la deuxième fois coupure de courant mais l'imprimante a pas voulu reprendre -_-'
j'ai lâché l'affaire du coup, c'est qu'il est gros le monsieur !
il y a 50 minutes, Pyroa a dit :
Comme c'est un tirage au sort, je me dis que même une impression partielle ou ratée reste une entrée valide (il faut juste assumer ... 😅 )
Et quand je regarde les commentaires de https://www.facebook.com/groups/1632161283639928/permalink/2049214588601260, 30 pour le moment, et il n'y a pas encore beaucoup de participants / d'entrées ( juste 2 ). Donc je dirais qu'il faut tenter ! même avec une impression ratée ...
@Pyroa
C'est bon ! J'ai posé la question à "Karl Fenton" (auteur du post du concours) et même une impression partielle reste une entrée valide ! alors à toi de jouer 🙂
Edit et je me dit que pour  @souriceaux cela se tente aussi ! non ? 🙂
@PPAC, Je vais essayer car je dois faire attention avec mes mains, toujours 'terrible'
J'ai retravaillé le fichier plus de 10h d'impression 😞
Modifié (le) par souriceaux
il y a 12 minutes, souriceaux a dit :
j’espère que tu n'as pas une allergie au nitrile ... et que cela vas passer.
Le 01/10/2022 at 12:12, PPAC a dit :
@Pyroa
Ah c'est gentil ca 🙂
ah ben je vias la poster alors 😛
Bonsoir à vous tous,
 @PPAC  la chaleur (d’où transpiration) en est la cause principale. J'ai eu tord d'utiliser deux fois de suite les mêmes gants.
Et c'est le cas de la dire, je m'en mords les doigts 🙂
Mon "TUTU" est sur le site comme celui là:
929297296_TuTuEiffelV3.thumb.jpg.998ffade58f1c1113a56457990d1c181.jpg20221002_193602.thumb.jpg.4c6ce41fd237cb5bb14801b36822c05f.jpg
Mais une question à ceux utilisant la version "CHITUBOX",
je me retrouve souvent lors de l'évidage puis le positionnement de supports du sujet avec à l'intérieur d'autres supports.
Est il possible d'éviter cela ?
Merci à vous pour vos réponses.
Il y a 10 heures, souriceaux a dit :
Sous Chitubox Pro, tu as, dans Support, un bouton "Advance" qui ouvre un panneau d'options avec de dé-cochable "Support in shell" est alors il ne devrais plus y avoir de supports dans le modèle évidé quand tu fait après un "+All"
Sinon faire un "+Platform" pour ne mettre que des support qui parte du plateau et compléter manuellement après
Ou alors il faut aller les supprimer a la main ( jouer avec l'affichage selon la hauteur et ou les plan X et Y et faire un cadre de sélection pour sélectionner les support en trop ... et cliquer sur le "-" )
Mais si il y a des supports d'ajouté automatiquement, cela peux supporter un îlot et donc tu risque d'avoir une impression déformé voir raté si tu les enlèves sans faire attention.
Et voilà, j'ai réitéré (je suis têtu)
Résultat très satisfaisant pour moi, posté sur le concours.
Maintenant que je maitrise plutôt bien ma machine, il faudrait que je passe aux buses 0.1
  • 3 weeks later...
Youpi ! après une longue période de suspense voici les résultats !
Donc il semble que le fait qu'il n'y ai que six entrées valide a remis en questions les lots mis en jeux et que finalement tous les participants semblent repartir avec une bouteille de résine.
https://www.facebook.com/groups/1632161283639928/posts/2081964865326232/
Under The Hotend T7UxpJ1Py3z.pngse sent hyper bien.
CHITUBOX GIVAWAY
to all that participated thankyou it was awsome seeing all the great prints on this event.
Sorry there has been a delay but here it is I e spoken to chitubox about your great prints and decided all 6 entrants deserve a prize so chitubox have decided you all deserve 1kg of resin 🙂.
@SabastianTutnichtszursache
Félicitation aux gagnants !
@Ironblue , @souriceaux , @Pyroa il me semble que nous somme tous dans les gagnants 🙂 !!!
Je ne sais pas encore comment on fait pour réclamer le prix, je vous tiens au courant !
il y a une heure, Ironblue a dit :
Cool, je vais commencer à apprécier facebook si ça continue....
là on a eu la chance de trouver des concours que je qualifierai de "concours de niche" (peux de participants) ...
mais ils sont rares et Facebook est, pour moi, un truc formidable ( = "Qui inspire une grande crainte.") ...
Edit
Peut être un autre concours niche ?
https://www.facebook.com/chitubox/posts/pfbid02K8qdJ5yfuaQUNGz4AW6aUWDSRh54ZJ4zj3d7WVqbGqWJhfUaT3kyWvtuZu8W7M7dl
cf pas grand monde pour le moment https://www.facebook.com/hashtag/chituhalloween
Il y a 8 heures, PPAC a dit :
Cool trop content 🙂
Il y a 10 heures, PPAC a dit :
Tous gagnants 🙂 . Vraiment superbe, ne reste plus que 'Jiaer Li' nous contacte
C'est fait pour moi, ce matin mais j'ai pu répondre que ce soir car j'utilise pas facebook sur mon téléphone....
Une autre opportunité pour peut-être avoir de la "Conjure Resin" 🙂
https://www.facebook.com/CBD3D/posts/pfbid0DsAKjH1kfpMA8qGY7rHofEvthy8KWzTTNL2K8MrH2KitqnSZGkyC9WSdTaypiQZ3l
🧙“Trick for Giveaways? Or Treat Resins for Halloween!”
Come to knock on our door to get your resin! 🎃
HOW TO GET YOUR RESIN:
Send a Message "Happy Halloween to ChiTu Systems!" to the contacts below.
📨Contact: Facebook DM / Email - lijiaer@cbd-3d.com
👉Prize: 500g Conjure Resin (Random Color) - Each Winner
📍Applicable Delivery Countries: US/UK/EU
(We will randomly choose 10 Winners to send out our RESIN.)
🧡Happy Halloween!! 🧟‍♀️
J'ai reçu ca dans la boite mail de mon compte facebook :
C'est le DM ? Facebook je m'y connais autant que la reproduction d'une amibe vénusienne.
Je suis trop vieux pour ces conneries !
En plus je ne retrouve pas le commentaire en cliquant sur le voir plus :s
[Edit] j'ai fini par trouver, DM ça doit être messenger 🙃, mais je n'ai toujours pas retrouvé le commentaire 🤣
