Nouveau firmware pour la P1P en version 01.03.00.00(20230608) :
  • Added support for downgrading to previous firmware versions controlled by Bambu Lab (Only through Handy APP V1.0.13 or above)
  • Added support for remote liveview through the Internet (Handy APP V1.2.0 or above, Studio V1.7.0.0 or above)
  • Added support for saving history print files(limited to 20 3mf files) from cloud to the local cache folder of the MicroSD card
  • Added support for smooth timelapse mode
  • Added support for multi-language display of files and settings, such as file names, accounts .etc
  • Added support for Bambu Studio/Handy displaying the number of print layers
  • Added support for using M710 G-code to control the MC fan
  • Optimized the decompression logic of printing to allow for printing and decompressing the 3mf file at the same time
  • Other improvements and bugs fixed
  • Remaining Issues
Je laisserai @molusk77 qui va récupérer la machine la mettre à jour, je reste sur la X1C moi 😛
Je l'ai appliqué hier mais commençant avec ce nouveau firmware, je n'ai pas de recul sur les différences avec ce qui précédait. Dans tous les cas, elle envoie du lourd en terme de productivité et de réussite. merci en passant @Motard Geek
Nouvelle version 01.04 aujourd'hui !
Permet de mettre l'interface en français.
Changelog :
Improvements】
  1. Improved printing stability.
  2. Optimized printing pause/AMS resume function. Now you can directly click the "Continue" button on the printing page to resume the AMS stalled state.
  3. Canceled the secondary menu for the light switch control. Now, selecting the menu item will turn the light on or off.
  4. Updated privacy policy.
【Bugs fixed】
  1. Fixed the problem of being unable to print in multiple colors from the MicroSD card.
  2. Fixed the problem with missing steps caused by not selecting automatic bed leveling during calibration.
  3. Fixed the problem where the file list does not automatically refresh when sending the sliced file to the printer.
  4. Fixed the printer restart problem caused by continuous reconnection of MQTT using third-party tools.
【Known Issues】
  1. It is possible that the printer printing built-in models will happen step loss.
  • Motard Geek changed the title to [P1P/P1S] Les firmwares (nouveautés des mises à jour)
Hello, un nouveau firmware pour la P1P au retour de congés.
P1 series OTA version01.04.00.00(20230807)
Résumé pour ma part :
  • Ajout d'une protection pour le lit chauffant lors d'un homing proche du fond.
    • bruit étrange en fin de position basse.
Modifié (le) par molusk77
  • 3 months later...
La version 01.05.00.00 arrive d'ici peu, elle est disponible en beta pour ceux qui sont inscrit au programme de beta.
Elle apporte entre autre le motor noise cancellation, et les timelapse depuis l'app mobile.
https://www.youtube.com/watch?v=L5uYFedvsfg
Modifié (le) par Rony
Mise à jour effectuée !
Certains ont testé durant la bêta peut être, la réduction de bruit sur la P1S ? C’est vraiment efficient significativement ?
Testé rapidement aujourd'hui, effectivement un peu plus calme.
Ce qui est sympa, c'est que l'on peut indiquer dans les préférences de la machine si on a installé le kit d'upgrade de la p1p vers la p1s. (ce qui est mon cas 😀 et du coup j'ai plus l'erreur sur bambu studio), et que l'on peut indiquer le type de buse utilisé (inox ou acier, ou 0.2 0.4....).
Si vous avez mis les menus en français sur la p1p/p1s, les nouvelles options disponibles sont mal traduits, j'ai du remettre en anglais pendant 2 minutes pour vérifier que je faisais pas de bêtise.
Modifié (le) par Sebg33
bonjour,  nouveau firmware:
01.05.01.00 Firmware which, according to the release notes, should fix the calibration stuck issue
bonjour,
nouveau firmware
  • 4 months later...
Bonjour. nouveau firmware pour les P1 : version 01.06.00.00 (20240611)
1-Nouvelles fonctionnalités :
Non-LAN binding via PIN code on the Studio side (in conjunction with Bambu Studio v01.09 and up)
Users can bind P1 devices to the computer that is not on the same local area network (LAN) using a PIN code on the studio side
Improved manual flow calibration parameters management
Auto-save the manual flow calibration parameter
Support creating & managing new PA parameters
Support setting PA configuration files on the filament settings page in Studio
Third-party filament support
Users can create and manage custom filament profiles in Studio. These custom filaments can then be selected in Studio Device filament slots, and then be synced to the printer and Handy.
Added filament verification for "Reducing purging through retracting filament" function
A long retraction during filament change can significantly reduce the purge volume, but it may cause clogging when the filaments assigned in the sliced file do not completely match the actual filaments in use. The filament verification function will verify the filaments match before performing retraction.
2-Améliorations :
Added secondary confirmation when stopping a print, as a safety to protect the user from accidentally canceling a print.
Optimized Total Print Time Calculation, add abnormal pausing time into the stat.
Auto filament type verification when printing with 3MF files from an SD card
Improved the Custom Device Name function to auto-save the custom name when logging out. The name will also synchronize across devices
3-Corrections de bug :
Fixed the button no response glitch when formatting the SD card
Fixed intermittent black screen after power-loss recovery
Optimized FW update printer status check for safer update
Optimized status verification when downloading a language package to avoid process conflict
Fixed the issue of devices being unable to send print jobs after not restarting for an extended period.
Prevent conflicts with Bambu Cloud service & potential damage to printer hardware by prohibiting crucial printer controls (initiating printing, heating the nozzle, and heating the heatbed) through the local MQTT Broker while the printer is logged into Bambu Cloud service.
Please note that this restriction will affect the use of software and hardware such as Home Assistant and BiQu Panda Touch. Suppose you still need to use such software and hardware to control the restricted functions. In that case, we recommend enabling the printer's LAN Only mode to continue using the restricted control functions with the Local MQTT Broker.
Nouveau firmware ce jour qui corrige quelques bugs + maj de l'AMS en v 06.44:
P1 series OTA version 01.06.01.00 (20240722)
Improvement
Improved system stability.
Bug fixes
  • Fixed the intermittent time synchronization failure.
  • Fixed the intermittent manual calibration failure.
  • Fixed the issue where there was a small chance the K factor from flow dynamics calibration was not effective.
Modifié (le) par nico_g77
  • 4 months later...
Nouveau firmware en 01.07.00.00
New Features
  1. Added support for offline Firmware update from MicroSD card. How to: Firmware Upgrade via microSD Card - P1 Series.
  2. Added support for filament editing while printing
  • Only the filament that is not in use can be edited.
  • The printer will automatically remap the filament backup according to the new filament settings.
Feature Optimizations
  1. Pause print if abnormal bed-leveling data exceed the threshold. This helps protect the buildplate from unwanted damage.
  2. Optimized UI Copy.
Bug Fixed
  1. Fixed the printer screen freeze problem when user using Bambu Handy to initialize the first calibration
  2. Fixed the printer restarting problem caused by saving the K-factor values.
  1. Ajout de la prise en charge de la mise à jour hors ligne du firmware à partir d’une carte MicroSD. Comment faire : Mise à niveau du micrologiciel via une carte microSD - Série P1.
  2. Ajout de la prise en charge de l’édition du filament pendant l’impression
  • Seul le filament qui n’est pas utilisé peut être modifié.
  • L’imprimante remappe automatiquement la sauvegarde du filament en fonction des nouveaux paramètres du filament.
Optimisations des fonctionnalités
  1. Interrompez l’impression si les données anormales de nivellement du lit dépassent le seuil. Cela permet de protéger la plaque de construction contre les dommages indésirables.
  2. Copie d’interface utilisateur optimisée.
Bug corrigé
  1. Correction du problème de gel de l’écran de l’imprimante lors de l’utilisation de Bambu Handy pour initialiser le premier étalonnage
  2. Correction du problème de redémarrage de l’imprimante causé par l’enregistrement des valeurs du facteur K.
  • Merci ! 2
Salut
Le 12/12/2024 at 21:23, Picsou a dit :
Si je comprends bien ce qui est écrit dans le Wiki cette option ne sera utilisable qu'après avoir installé la version 01.07.00.00 et donc pour les versions ultérieures.
Je vais devoir connecter ma P1S au WiFi pour faire la mise à jour du firmware. Je suis en version 01.05.01.00
A+
JC
  • Julien unpinned this topic
  • 1 year later...
Salut
Les P1P/P1S ne sont pas (encore) mortes 😉 Une nouvelle version de firmware est dispo depuis 2 jours --> https://wiki.bambulab.com/en/p1/manual/p1p-firmware-release-history
P1 series Version 01.09.01.00 (20260114)
  1. Ajout du soutien pour les Chinois traditionnels.
  2. Ajout d'une bascule marche/arrêt pour la bobine tournante lors du séchage AMS 2 Pro/AMS HT.
  3. Ajout d’un indicateur de bobine externe « EXT » à l’interface de chargement et de déchargement.
Optimisation de la fonctionnalité
  1. Mises à jour de sécurité.
  2. Correction d'un problème de communication AMS occasionnel.
  3. Correction d'un problème où les travaux d'impression pouvaient être envoyés avec succès en mode LAN, mais l'imprimante ne répondait pas.
  4. Correction d'un problème où une unité AMS HT pouvait occasionnellement ne pas sécher lorsque plusieurs unités AMS HT étaient connectées.
  5. Correction d'un problème où le moteur AMS continuait à fonctionner après la purge du filament à l'extrémité d'une bobine.
  6. Correction d'un problème où le réglage du matériau passait incorrectement à ASA après avoir activé le séchage au PLA.
  7. Correction d'un problème où les commandes d'arrêt initiées à partir de Bambu Handy pendant le chargement ou le déchargement du filament ne prenaient pas effet.
  8. Correction d'un problème où la rétractation était sautée avant la découpe du filament lors de l'utilisation de profils PETG génériques.
  9. Il est recommandé de mettre à jour l'AMS vers la version 00.00.06.75, qui résout les problèmes suivants.
  • Correction du problème où l'action de préchargement continuait occasionnellement de fonctionner en continu.
  • Correction du problème où la configuration des paramètres ou la réinitialisation des informations sur les filaments échouaient occasionnellement.
  • Correction du problème où la lumière rouge échouait occasionnellement à clignoter après avoir réinitialisé AMS.
(Traduction Firefox)
À combiner avec une mise à jour de l'AMS avec la version  00.00.06.75 que je n'ai pas trouvé dans le wiki
Installation prévue ce weekend
A+
JC
