itopie Posté(e) Mars 21, 2020 Partager Posté(e) Mars 21, 2020 (modifié) Bonjour, j'ai récemment installé octopi sur une raspberry pi 3 mais je rencontre des difficultés avec la caméra... C'est une webcam logitech c270 filmant en HD 720p en 30fps. J'ai vu que cette caméra était souvent utilisée pour octopi mais je n'ai pas réussi à la faire fonctionner. J'ai paramétré le fichier octopi.txt comme ça : ### Windows users: To edit this file use Notepad++, VSCode, Atom or SublimeText. ### Do not use Notepad or WordPad. ### MacOSX users: If you use Textedit to edit this file make sure to use ### "plain text format" and "disable smart quotes" in "Textedit > Preferences" ### Configure which camera to use # # Available options are: # - auto: tries first usb webcam, if that's not available tries raspi cam # - usb: only tries usb webcam # - raspi: only tries raspi cam # # Defaults to auto # camera="usb" ### Additional options to supply to MJPG Streamer for the USB camera # # See https://faq.octoprint.org/mjpg-streamer-config for available options # # Defaults to a resolution of 640x480 px and a framerate of 10 fps # camera_usb_options="-r 1280x720 -f 30" ### Additional webcam devices known to cause problems with -f # # Apparently there a some devices out there that with the current # mjpg_streamer release do not support the -f parameter (for specifying # the capturing framerate) and will just refuse to output an image if it # is supplied. # # The webcam daemon will detect those devices by their USB Vendor and Product # ID and remove the -f parameter from the options provided to mjpg_streamer. # # By default, this is done for the following devices: # Logitech C170 (046d:082b) # GEMBIRD (1908:2310) # Genius F100 (0458:708c) # Cubeternet GL-UPC822 UVC WebCam (1e4e:0102) # # Using the following option it is possible to add additional devices. If # your webcam happens to show above symptoms, try determining your cam's # vendor and product id via lsusb, activating the line below by removing # and # adding it, e.g. for two broken cameras "aabb:ccdd" and "aabb:eeff" # # additional_brokenfps_usb_devices=("aabb:ccdd" "aabb:eeff") # # If this fixes your problem, please report it back so we can include the device # out of the box: https://github.com/guysoft/OctoPi/issues # #additional_brokenfps_usb_devices=() ### Additional options to supply to MJPG Streamer for the RasPi Cam # # See https://faq.octoprint.org/mjpg-streamer-config for available options # # Defaults to 10fps # #camera_raspi_options="-fps 10" ### Configuration of camera HTTP output # # Usually you should NOT need to change this at all! Only touch if you # know what you are doing and what the parameters mean. # # Below settings are used in the mjpg-streamer call like this: # # -o "output_http.so -w $camera_http_webroot $camera_http_options" # # Current working directory is the mjpg-streamer base directory. # #camera_http_webroot="./www-octopi" #camera_http_options="-n" Mais sur octopi lorsque je vais dans l'onglet "control" je vois un écran noir avec ce message : "webcam stream loading..." J'ai essayé sur firefox et chrome. Ce qui est étrange, c'est lorsque j’éteins octopi en cliquant sur "shutdown" sur la page web, un message apparait pour confirmer et lorsque je valide une photo prise par la webcam apparait au 3/4. J'espère que vous pourrait m'aider. Merci. Modifié (le) Mars 21, 2020 par itopie Lien vers le commentaire Partager sur d’autres sites More sharing options...
Thierry94 Posté(e) Mars 21, 2020 Partager Posté(e) Mars 21, 2020 Normalement avec octopi il n'y a rien à modifier il suffit d'activer la caméra dans rasp-config sur le pi ! Essaye déjà comme ça et seulement après, si besoin, modifie les paramètres d'octopi pour avoir la resolution souhaitée Lien vers le commentaire Partager sur d’autres sites More sharing options...
itopie Posté(e) Mars 21, 2020 Auteur Partager Posté(e) Mars 21, 2020 Avant de toucher au fichier octopi.txt j'ai bien évidemment essayé la caméra sans ne rien configurer mais elle ne marchait pas. Je vais réinstaller octopi de 0 au cas où, merci ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Thierry94 Posté(e) Mars 21, 2020 Partager Posté(e) Mars 21, 2020 Attention il faut que la caméra soit branchée avant de mettre sous tension le pi Lien vers le commentaire Partager sur d’autres sites More sharing options...
itopie Posté(e) Mars 22, 2020 Auteur Partager Posté(e) Mars 22, 2020 J'ai réinstallé octopi sur une autre carte SD sans toucher au réglage, en branchant la caméra avant mais même problème… Lorsque j’arrête octopi une photo apparait, comme avant. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Thierry94 Posté(e) Mars 22, 2020 Partager Posté(e) Mars 22, 2020 Si tu fais http://ipdupi:8080 tu obtiens quoi ? Normalement tu devrais avoir une page avec un snapshoot et un streaming de la webcam Lien vers le commentaire Partager sur d’autres sites More sharing options...
itopie Posté(e) Mars 22, 2020 Auteur Partager Posté(e) Mars 22, 2020 Lorsque je fais http://octopi.local:8080/ j’obtiens une photo de la caméra mais pas de vidéo, la page continue de charger Lien vers le commentaire Partager sur d’autres sites More sharing options...
