voron V2.4 R2 PRO de chez fysetc quelq'un a t'il deja monter ce projet ?
donc la pour com en CAN c'est le premier ecran de katapult dans le menuconfig on est d accord ?
pourquoi juste en dessous il parle de klipper direct ?
kekito@kevin:~/katapult $ make flash FLASH_DEVICE=0483:df11
  Flashing out/katapult.bin to 0483:df11
[sudo] password for kekito:
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
DfuSe interface name: "Internal Flash  "
Downloading to address = 0x08000000, size = 4456
Download        [=========================] 100%         4456 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
dfu-util: can't detach
Resetting USB to switch back to runtime mode
la on est ok pour katapult
kekito@kevin:~/katapult $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 1a86:8091 QinHeng Electronics USB HUB
Bus 001 Device 003: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
la on est au moment ou je coupe l'imprimante debranche l' usb et branche le can
kekito@kevin:~ $ lsusb
kekito@kevin:~ $ ~/klippy-env/bin/python ~/klipper/scripts/canbus_query.py can0
Found canbus_uuid=d24426461edb, Application: Klipper
Total 1 uuids found
et on retourne exactement a la meme chose que l'autres fois je comprend pas ............
il y a 22 minutes, Kekito a dit :
oui c'est le bon moment.
pour le flash de klipper c'est le premier écran aussi.
le 2ème c'est pour la version usb
le 3ème pour klipper en canbus tout seul sans katapult
le 4ème pour klipper en usb tout seul sans katapult
Modifié (le) par Savate
il y a 1 minute, Savate a dit :
yes mais toujours pareil que l'autre fois du coup lol
à l’instant, Kekito a dit :
c'est à dire ?
pas d'uuid ?
c'est à dire ?
pas d'uuid ?
yes regarde juste au dessus je t'ai mis la copie
1 uuid found
il y a 25 minutes, Kekito a dit :
tu as bien préparé le premier écran pour katapult ?
SB_Combo_V2_menuconfig_8k_CAN
il y a 1 minute, Kekito a dit :
le premier ecran d'ici j'ai pris cela correspond pas avec ce que tu ma
oui désolé la fatigue de la journée c'est toi qui as le bon.
dans katapult
fais un
make clean
make
et essaye de reflasher la carte (je ne suis pas sur que le firmware soit bien compilé)
(avant il il faut rebrancher la carte en usb et la repasser en dfu)
dans katapult
fais un
make clean
make
je viens de repasser en usb ,du coup en dfu par la meme occasion
3
kekito@kevin:~ $ cd ~/katapult
kekito@kevin:~/katapult $ make clean
  Creating symbolic link out/board
  Building out/autoconf.h
  Compiling out/src/sched.o
  Compiling out/src/bootentry.o
  Compiling out/src/command.o
  Compiling out/src/flashcmd.o
  Compiling out/src/initial_pins.o
  Compiling out/src/led.o
  Compiling out/src/generic/armcm_canboot.o
  Compiling out/src/stm32/gpio.o
  Compiling out/src/stm32/flash.o
  Compiling out/src/stm32/clockline.o
  Compiling out/src/stm32/dfu_reboot.o
  Compiling out/src/generic/armcm_irq.o
  Compiling out/src/generic/crc16_ccitt.o
  Compiling out/src/../lib/stm32f0/system_stm32f0xx.o
  Compiling out/src/stm32/stm32f0.o
  Compiling out/src/stm32/stm32f0_timer.o
  Compiling out/src/stm32/gpioperiph.o
  Compiling out/src/generic/canserial.o
  Compiling out/src/../lib/fast-hash/fasthash.o
  Compiling out/src/stm32/can.o
  Compiling out/src/generic/canbus.o
  Compiling out/src/stm32/chipid.o
  Building out/compile_time_request.o
  Preprocessing out/src/generic/armcm_link.ld
  Linking out/katapult.elf
  Creating bin file out/katapult.bin
  Creating legacy binary out/canboot.bin
dfu-util 0.9
ID 0483:df11
dfuIDLE, continuing
Download done.
comme si il ne memorise pas ...........
pourtant tout es ok la ?
il y a 5 minutes, Kekito a dit :
pourquoi comme si il ne mémorise pas ?
là ça semble pas mal
Si ça ne marche pas : sens canl / canH ou flash de la cm foireux.
bon je vais eteindre rebrancher avec le can voir si sa sort quelque chose
jai inverti deja le sens du L et H on va voir si sa sort ou pas
sinon on reprend le flash de la CM ?
c'est cuit toujours pas d'uuids de la TH
je sais pas se que tu en pense hein mais je comprend pas d ou viens le probleme on a l uuid de la CM
on flash correctement la TH et on ne trouve pas son uuid
faut RAZ la totalité la non ?
Il y a 11 heures, Kekito a dit :
si les ports de sortie can de la cm n'étaient pas bons lors du flash : la cm est bien vue, mais pas la TH. (et une erreur est vite arrivée 🙂)
Comme Katapult est déjà installé (et qu'il n'utilise pas les ports can) tu peux te contenter de ne flasher que klipper.
cd klipper
make menuconfig
make clean
make
sudo service klipper stop
passage de la CM en mode katapult :
python3 ~/katapult/scripts/flashtool.py -i can0 -r -u d24426461edb
retrouver le nom du port série :
ls /dev/serial/by-id/*
qui doit retrouner un usb_katapult.... qu'il faudra changer dans la commande ci-dessous
python3 ~/katapult/scripts/flashtool.py -f ~/klipper/out/klipper.bin -d /dev/serial/by-id/usb-katapult_yourmainboardusbid
sudo service klipper start (ou un reboot de la machine)
salut salut je m occupe de ca de suite du coup
kekito@kevin:~/klipper $ python3 ~/katapult/scripts/flashtool.py -i can0 -r -u d24426461edb
Flashing CAN UUID d24426461edb on interface can0
ERROR:root:Flash Error
Traceback (most recent call last):
  File "/home/kekito/katapult/scripts/flashtool.py", line 481, in run
    self.cansock.bind((intf,))
OSError: [Errno 19] No such device
During handling of the above exception, another exception occurred:
  File "/home/kekito/katapult/scripts/flashtool.py", line 661, in main
    await sock.run(intf, uuid, fpath, req_only)
  File "/home/kekito/katapult/scripts/flashtool.py", line 483, in run
    raise FlashError("Unable to bind socket to can0")
FlashError: Unable to bind socket to can0
kekito@kevin:~/klipper $ ls /dev/serial/by-id/*
ls: cannot access '/dev/serial/by-id/*': No such file or directory
Sending bootloader jump command...
Bootloader request command sent
Flash Success
/dev/serial/by-id/usb-katapult_stm32f446xx_250047000C51333134383631-if00
kekito@kevin:~/klipper $ python3 ~/katapult/scripts/flashtool.py -f ~/klipper/out/klipper.bin -d /dev/serial/by-id/usb-katapult_stm32f446xx_250047000C51333134383631-if00
Flashing Serial Device /dev/serial/by-id/usb-katapult_stm32f446xx_250047000C51333134383631-if00, baud 250000
Attempting to connect to bootloader
Katapult Connected
Software Version: v0.0.1-79-g25a23cd
Protocol Version: 1.1.0
Block Size: 64 bytes
Application Start: 0x8008000
MCU type: stm32f446xx
Flashing '/home/kekito/klipper/out/klipper.bin'...
Write complete: 2 pages
Verifying (block count = 487)...
Verification Complete: SHA = 4288B2D36C2BD9C7FBE316250F1CC588E7026776
Flash Success
sa ma l'air detre plutot pas mal l histoire pour le moment
Total 1 uuids found
kekito@kevin:~ $
et voila le resultat toujours pareil du coup je comprend pas ......
