Le montage du kit est fait :-)
Reste à voir comment ça fonctionne !? si vous avez des tuto, je suis preneur
La première chose a faire sera d'uploader le Marlin avec les paramètres en fonction de l'imprimante (je ne suis pas encore un bon en Marlin, mais voici déjà des pistes):
1°) ENDSTOP :
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
2°) LIMITES DU PLATEAU :
// Travel limits after homing
#define X_MAX_POS 220
#define X_MIN_POS 0
#define Y_MAX_POS 220
#define Y_MIN_POS 0
#define Z_MAX_POS 180
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
3°) LES TEMPERATURES :
/ The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 24
#define HEATER_1_MINTEMP 24
#define HEATER_2_MINTEMP 24
#define BED_MINTEMP 30
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 300
#define HEATER_1_MAXTEMP 300
#define HEATER_2_MAXTEMP 300
#define BED_MAXTEMP 150
4°) LIBRAIRIE ARDUINO POUR L'ECRAN LCD :
https://bintray.com/olikraus/u8glib/Arduino
Elle sera à intégrer sous Arduino comme librairie par :
Croquis > importer > Add librairie
Tu choisis le zip de la librairie
Relancer arduino afin qu'elle soit prise en compte.
Il doit certainement manquer des choses, mais les pro du Marlin feront le complément.
Modifié (le) par nicephore
C'est un bon début :
Ramps 1.4 + carte Mega 2560 + Full Graphic Smart LCD Controller + Alimentation ATX modifiée + 3 venitlos 120mm
y3m5cTJcKtc35Zjv2aZOQwvJqpCbbgb1cT4jfFRP
Il y a 7 heures, Doc Sly a dit :
Est-ce normal que je ne puisse pas accéder au menu sur l'ecran ?
oui normal avec l'erreur MinTemp
si tu veux faire des tests il faut que tu passe tes mintemp a 0 dans marlin
il y a une heure, watcher330 a dit :
Cool, ca fonctionne avec les MINTEMP à 0 :-)
Coucou, bon, le SAV m'as renvoyé les drivers, et j'ai recommandé un kit ramp / arduino ^^
j'ai arrangé un peut mes cables, et imprimé une boite avec ventilo pour acceuillir l'arduino
Photo is comming ;)
Salut @kohrne , as-tu installé un palpeur ? Comment as-tu procédé ? carte additionnel, modification du câblage pour connexion sur le endstop Z ?
Je ne vois pas d'emplacement pour l'installation des EndStop ! tu les a installés ?
salut @Doc Sly, J'ai mis un capteur inductif sur la d32 de la ramp en plus d'un Zmin classique (je suis en train de configurer tout ça)
Pour les endstop, le x et y sont prévu dans le charriot et un des angle opposé au moteur (je fais des photos demain, promis ;) )
Merci pour tes reponses.
Je doit recevoir mes EndStop demain, j'ai deja un palpeur en stock.
J'attend impatiemment tes photos.
bon après un peu (beaucoup) d'aide de l'IRC, j'ai pu faire mon premier print !!! :)
Quel bonheur ces TMC2100 ... :x
du coup, j'ai un endstop en bas en Zmax, et le probe qui me sert de Zmin (il suffisais de se creuser la tête dans Marlin ^^)
Bon il me reste donc plus qu'a peaufiné les réglages pour avoir une impression de qualité :)
Modifié (le) par kohrne
ca avance ! tiens nous au courant.
Moi je viens de recevoir mes EndStop.
Prochaine commande : la structure alu, pignon et courroie.
pour les écrous, selon tes profilés,  pense bien a prendre des hm (fin), les normaux ne passe pas en épaisseur ;)
salut,
j'ai pris celles ci : http://fr.aliexpress.com/item/Free-Shipping-for-1pc-SFU1204-Ball-Srew-L500mm-Ballscrews-1pc-1204-ball-nut-without-end-machined/1834481958.html
Pour le coupleur, c'est du 5/8 qu'il faut ;)
Pour la config, ça donnera 800 step/ unit en Z
Et si tu es en simple extrudeur, je te conseil de mettre le second moteur Z sur l'extrudeur 2 pour soulager les driver
Elle tourne comme un charme ! elle est nickel en 200 microns,
je n'ai pas encore pris le temps de la calibrée pour une meilleur précision (mémoire, PFE tout ça tout ça ^^)
Je ferais un retour complet ainsi que quelques photos de mes prints début juillet (après le rush).
Okay , j'attends avec impatience car je pense faire aussi cette vulcanus max 30
