Nouveau firmware pour les X1 en ligne 🙂
  • Added a pop-up message for the first boot after updates to remind users to open AI monitoring function and remind defaultly to check if the carbon rods need to be cleaned
  • Added equipment maintenance reminders when carbon rods need to be cleaned and Z-axis lead screws need to be lubricated
  • Supported encryption of data and control commands between printers and Bambu Studio in LAN mode to improve security in LAN
  • Added support for up to 8 cloud printing 3mf files to be cached in the MicroSD Card
  • Added support for connecting to the printer by directly entering the IP Address and Access Code. This must be used with the latest version of Bambu Studio
  • Added support for displaying the current layer number/total number of layers during printing
  • Added secondary confirmation when stopping a printing job in a pop up window
  • Optimized thermal runaway protection for the hotend
  • Improvements and bugs fixed
  • Details
Source : https://wiki.bambulab.com/en/x1/manual/X1-X1C-AMS-firmware-release-history
J'espère que le double check pour cancel print arrivera avec la prochaine MAJ P1P 😄
On peut faire un topic dédié au MAJ si vous préférez 😛
  • 4 weeks later...
Dernier Firmware en date (27.02.2023)  version 01.04.01.00
【Improvements】
1. [Algorithm] Optimized the HMS prompt explaining that the PEI build plate does not support first layer inspection.
pei%E4%B8%8D%E6%94%AF%E6%8C%81%E9%A6%96%
2. [System] Updated some HMS and screen content.
3. [System] Adjusted the page layout and deleted the video and live icon on the thumbnail of the home page during printing, only retaining the delayed photography icon.
%E5%BB%B6%E6%97%B6%E6%91%84%E5%BD%B1%E5%
【Bugs fixed】
1. [System] Fixed the issue of abnormal extrusion compensation caused by the large velocity difference between the inner and outer walls.
2. [System] Fixed a low probability issue where the avatar of the bound user is not displayed.
Quelqu'un l'a t'il fait ? pour le moment je l'ai refusé car j'ai vu passer quelques retours négatif sur ce firmware. "une baisse de la précision d'impression"  ???
Modifié (le) par 6ti4
Oui je l'ai faite l'autre jour. RAS de mon côté niveau impressions.
  • Merci ! 2
Surprise ce soir en allumant la machine
OTA version 01.05.01.00 (20230426)
  • Added support for setting properties and loading/unloading filament on the spool holder
  • Added support for downgrading to previous firmware versions controlled by Bambulab (Only through Handy APP V1.0.13 or above)
  • Added support for quick issue reporting through the popup window on the screen when printing is completed or stopped manually
  • Added support for resetting aftermarket filament information after inserting it into a slot when the printer is idle
  • Added a pop-window for filaments which are not supported or need attention by AMS when setting up and printing
  • Added a QR code link to the firmware version page to view previous release notes
  • Added the color setting of filament based on AMS's existing colors
Avec l'ajout de la prise en charge de la définition des propriétés et du chargement/déchargement du filament sur le porte-bobine
Ce serais bien d'avoir un système pour éviter de débrancher l' AMS a chaque fois, j'ai vu quelques systèmes mais il me semble pas très fiable 🤨
Alain
il y a 54 minutes, BOUBOU33 a dit :
Alain
Y a pas besoin de débrancher l'AMS : il suffit de sélectionner "ne pas utiliser l'AMS" au lancement du print...
  • +1 2
oui mais je parlais au niveau du PTFE
Alain
Le 28/04/2023 at 14:30, BOUBOU33 a dit :
Le sujet a déjà été discuté ici. Pour ma part, je ne débranche que le PTFE côté bobine pour insérer le filament jusqu'à l'extrudeur en ayant évidemment décocher l'utilisation de l'AMS dans la boîte de dialogue d'envoi de l'impression. 😉
Mais je vais faire la MAJ immédiatement pour voir cette nouvelle fonction....
Alain
il suffit d'un splitter... J'en ai monté un de suite, je n'ai débranché l'AMS que quand j'ai installé l'imprimante dans le caisson PAX installé après... Et pourtant j'utilise assez souvent une bobine externe...
  • 1 month later...
Nouveau firmware disponible pour la X1, en version qui apporte les changement suivants :
  • Added support for load/unload function (only with external spool holder) when printing is paused
  • Optimized the filament setting and display logic
  • Bugs fixed
Le changement de filament en spool externe c'est cool ça (pour le TPU par exemple) 🙂
Il y a 8 heures, Motard Geek a dit :
oui, enfin si je lis bien, pour l'instant cela ne fonctionne que quand on utilise seulement le spool holder...
il y a 7 minutes, Motard Geek a dit :
C'est ce que j'ai écrit non ?
Certes, mais je pense que la vrai possibilité que nous attendons tous c'est la possibilité de travailler avec l'AMS et de faire le changement manuel vers le spool externe pour le TPU... Donc un mix Spool externe/AMS... Or pour l'instant, la pause n'est pas reconnue quand utilisation de l'AMS...
  • 1 month later...
C'est sur, mais moi, c'est surtout le fait de permettre d'arrêter d'imprimer un objet sur une impression de plusieurs objets que je trouve super.
En tout cas, chez Bambu, ils ne se reposent pas sur leurs lauriers !
Je liste ici toutes les nouveautés, car il y a vraiment plein de changements 🤩, toute la liste est disponible ici sur leur wiki :
  • Le bug qui pouvait entraîner le plateau à aller plus bas que ce qui est possible au début d'une impression si le plateau était presque en bas est corrigé
  • Comme l'a dit @Baroudeur, on peut maintenant dire à l'imprimante d'arrêter d'imprimer un objet en cours d'impression directement sur l'écran de l'imprimante, par exemple dans le cas où l'un d'entre eux ne s'est pas imprimé correctement (ça rajoute un intérêt à l'écran). Attention, ce n'est pas possible dans les cas suivants impression en multi couleurs, plus de 64 objets sur la plaque et si le fichier a été préparé avec une version de Bambu Studio inférieure à la 1.6
Révélation
  • Il est désormais possible de visualiser le flux vidéo en étant en mode LAN, il suffit d'activer une option dans les paramètres
Révélation
  • Ajout d'une interface spécifique à l'auto refill, où l'on peut définir quelle bobine remplacera une bobine dans le cas où la première serait vide.
Révélation
  • Pour les améliorations pour la calibration, le mieux est de regarder les vidéos que @drogendo a posté. J'ajoute juste que le pattern de calibration prend désormais moins de place sur le plateau et qu'il est possible de l'utiliser avec une plaque en PEI texturé
  • Il est désormais possible d'accéder aux paramètres de calibration que l'imprimante a calculé automatiquement et même de les modifier
  • Il est désormais possible de gérer les fichiers qui sont présents sur la carte SD de l'imprimante directement depuis Bambu Studio (possible de les supprimer, de les télécharger et de les imprimer)
Révélation
  • [Expérimental] L'imprimante peut désormais faire l'analyse de la première couche avec une plaque en PEI texturé. Attention c'est expérimental, donc rien ne garanti que ça fonctionnera à 100% du temps
  • J'aime 2
Il y a 11 heures, Baroudeur a dit :
J'ai pas vu ça je suis curieux
@drogendo
La procédure est achti simple, lorsque la machine imprime on clique sur le bouton en bas à gauche avec la flèche courbée (le chiffre indique combien l'impression va sauter de parties)
Tu as sur la gauche un gros carré qui zoome et affiche le résultat à droite et il suffit de choisir la (ou les) pièce défaillante, elle apparait en rouge, puis de valider en cliquant "Ignorer les objets"
Par contre comme je n'ai aucun décollement de pièces avec la 3DLac, je ne peux pas te dire si ça marche 🙃
EDIT : Et en plus, depuis l'application mobile, ça marche aussi, super pratique si on se rend compte sur son téléphone qu'une pièce dégoise !
Modifié (le) par Baroudeur
Il y a 16 heures, Baroudeur a dit :
@drogendo
Merci, trop bien comme ajout !
il y a 24 minutes, drogendo a dit :
Bizarre j'ai pas le problème.
humm, c'est bien gênant ça, si c'est que certaines personnes qui ont le souci 🤔
Bonjour, je viens d'essayer, valeur à 0 pour moi aussi (PLA sur Cold Plate)
