@fran6p Tu comprends quelque chose de ce charabia ?
Révélation
> Executing task in folder Marlin-2.0.x: C:\.platformio\penv\Scripts\platformio.exe debug <
Processing LPC1769 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.2.zip; board: nxp_lpc1769; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1769.html
PLATFORM: NXP Arduino LPC176x 0.1.1 > NXP LPC1769
HARDWARE: LPC1769 120MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
PACKAGES: toolchain-gccarmnoneeabi 1.80201.190214 (8.2.1), framework-arduino-lpc176x 0.2.2
Converting Marlin.ino
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <Servo> 1.0.0
|-- <LiquidCrystal> 1.0.0
|-- <U8glib-HAL> 0.4.1
|-- <TMCStepper> 0.6.2
|-- <Adafruit NeoPixel> 1.3.0
|-- <SailfishLCD>
Building in debug mode
Unable to find destination disk (Autodetect Error)
Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1769/firmware.bin) manually to the appropriate disk
Compiling .pio\build\LPC1769\src\src\HAL\HAL_LPC1768\DebugMonitor.cpp.o
Compiling .pio\build\LPC1769\src\src\HAL\HAL_LPC1768\HAL.cpp.o
In file included from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/MarlinConfigPre.h:37,
                 from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/MarlinConfig.h:28,
                 from Marlin\src\HAL\HAL_LPC1768\../../core/serial.h:24,
                 from Marlin\src\HAL\HAL_LPC1768\DebugMonitor.cpp:26:
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../../Configuration.h:133: warning: "BOARD_BIGTREE_SKR_V1_4_TURBO" redefined
   #define BOARD_BIGTREE_SKR_V1_4_TURBO //Guillaume
In file included from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/MarlinConfigPre.h:35,
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../core/boards.h:227: note: this is the location of the previous definition
 #define BOARD_BIGTREE_SKR_V1_4_TURBO  2508  // BigTreeTech SKR v1.4 TURBO (Power outputs: Hotend0, Hotend1, Fan, Bed)
In file included from Marlin\src\HAL\HAL_LPC1768\../../inc/MarlinConfigPre.h:37,
                 from Marlin\src\HAL\HAL_LPC1768\../../inc/MarlinConfig.h:28,
                 from Marlin\src\HAL\HAL_LPC1768\HAL.cpp:25:
Marlin\src\HAL\HAL_LPC1768\../../inc/../../Configuration.h:133: warning: "BOARD_BIGTREE_SKR_V1_4_TURBO" redefined
In file included from Marlin\src\HAL\HAL_LPC1768\../../inc/MarlinConfigPre.h:35,
Marlin\src\HAL\HAL_LPC1768\../../inc/../core/boards.h:227: note: this is the location of the previous definition
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../core/boards.h:346:64: error: operator '==' has no right operand
 #define _MB_1(B)  (defined(BOARD_##B) && MOTHERBOARD==BOARD_##B)
Marlin\src\HAL\HAL_LPC1768\../../core/macros.h:161:29: note: in expansion of macro '_MB_1'
 #define _DO_1(W,C,A)       (_##W##_1(A))
Marlin\src\HAL\HAL_LPC1768\../../core/macros.h:173:28: note: in expansion of macro '_DO_1'
 #define __DO_N(W,C,N,V...) _DO_##N(W,C,V)
Marlin\src\HAL\HAL_LPC1768\../../core/macros.h:174:28: note: in expansion of macro '__DO_N'
 #define _DO_N(W,C,N,V...)  __DO_N(W,C,N,V)
Marlin\src\HAL\HAL_LPC1768\../../core/macros.h:175:28: note: in expansion of macro '_DO_N'
 #define DO(W,C,V...)       _DO_N(W,C,NUM_ARGS(V),V)
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../core/boards.h:347:19: note: in expansion of macro 'DO'
 #define MB(V...)  DO(MB,||,V)
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../pins/pins.h:391:7: note: in expansion of macro 'MB'
 #elif MB(BIGTREE_SKR_V1_4_TURBO)
In file included from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/MarlinConfig.h:32,
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../pins/pins.h:622:6: error: #error "Unknown MOTHERBOARD value set in Configuration.h"
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../pins/pins.h:1298:8: error: #error "No E stepper plug left for Z2!"
Marlin\src\HAL\HAL_LPC1768\../../inc/../core/boards.h:346:64: error: operator '==' has no right operand
Marlin\src\HAL\HAL_LPC1768\../../inc/../core/macros.h:161:29: note: in expansion of macro '_MB_1'
Marlin\src\HAL\HAL_LPC1768\../../inc/../core/macros.h:173:28: note: in expansion of macro '_DO_1'
Marlin\src\HAL\HAL_LPC1768\../../inc/../core/macros.h:174:28: note: in expansion of macro '__DO_N'
Marlin\src\HAL\HAL_LPC1768\../../inc/../core/macros.h:175:28: note: in expansion of macro '_DO_N'
Marlin\src\HAL\HAL_LPC1768\../../inc/../core/boards.h:347:19: note: in expansion of macro 'DO'
Marlin\src\HAL\HAL_LPC1768\../../inc/../pins/pins.h:391:7: note: in expansion of macro 'MB'
In file included from Marlin\src\HAL\HAL_LPC1768\../../inc/MarlinConfig.h:32,
Marlin\src\HAL\HAL_LPC1768\../../inc/../pins/pins.h:622:6: error: #error "Unknown MOTHERBOARD value set in Configuration.h"
Marlin\src\HAL\HAL_LPC1768\../../inc/../pins/pins.h:1298:8: error: #error "No E stepper plug left for Z2!"
In file included from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/MarlinConfig.h:38,
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/SanityCheck.h:57:4: error: #error "MOTHERBOARD is required. Please update your configuration."
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/SanityCheck.h:514:4: error: #error "If NUM_Z_STEPPER_DRIVERS is 2, you must define stepper pins for Z2."
In file included from Marlin\src\HAL\HAL_LPC1768\../../inc/MarlinConfig.h:38,
Marlin\src\HAL\HAL_LPC1768\../../inc/SanityCheck.h:57:4: error: #error "MOTHERBOARD is required. Please update your configuration."
Marlin\src\HAL\HAL_LPC1768\../../inc/SanityCheck.h:514:4: error: #error "If NUM_Z_STEPPER_DRIVERS is 2, you must define stepper pins
for Z2."
compilation terminated due to -fmax-errors=5.
*** [.pio\build\LPC1769\src\src\HAL\HAL_LPC1768\DebugMonitor.cpp.o] Error 1
*** [.pio\build\LPC1769\src\src\HAL\HAL_LPC1768\HAL.cpp.o] Error 1
==================================================== [FAILED] Took 5.44 seconds ====================================================
Environment                   Status    Duration
megaatmega2560                IGNORED
megaatmega1280                IGNORED
rambo                         IGNORED
FYSETC_F6_13                  IGNORED
FYSETC_F6_14                  IGNORED
sanguino_atmega644p           IGNORED
sanguino_atmega1284p          IGNORED
melzi                         IGNORED
melzi_optiboot                IGNORED
at90usb1286_cdc               IGNORED
at90usb1286_dfu               IGNORED
DUE                           IGNORED
DUE_USB                       IGNORED
DUE_debug                     IGNORED
LPC1768                       IGNORED
LPC1769                       FAILED    00:00:05.443
STM32F103RC                   IGNORED
STM32F103RC_fysetc            IGNORED
STM32F103RC_bigtree           IGNORED
STM32F103RC_bigtree_USB       IGNORED
STM32F103RC_bigtree_512K      IGNORED
STM32F103RC_bigtree_512K_USB  IGNORED
STM32F103RE                   IGNORED
STM32F103RE_bigtree           IGNORED
STM32F103RE_bigtree_USB       IGNORED
STM32F4                       IGNORED
STM32F7                       IGNORED
ARMED                         IGNORED
STM32F103VE_GTM32             IGNORED
STM32F103VE_longer            IGNORED
mks_robin_mini                IGNORED
mks_robin_nano                IGNORED
mks_robin                     IGNORED
mks_robin_pro                 IGNORED
mks_robin_lite                IGNORED
mks_robin_lite3               IGNORED
jgaurora_a5s_a1               IGNORED
STM32F103CB_malyan            IGNORED
chitu_f103                    IGNORED
STM32F401VE_STEVAL            IGNORED
FLYF407ZG                     IGNORED
FYSETC_S6                     IGNORED
STM32F407VE_black             IGNORED
BIGTREE_SKR_PRO               IGNORED
BIGTREE_GTR_V1_0              IGNORED
BIGTREE_BTT002                IGNORED
teensy31                      IGNORED
teensy35                      IGNORED
esp32                         IGNORED
linux_native                  IGNORED
SAMD51_grandcentral_m4        IGNORED
rumba32_f446ve                IGNORED
mks_rumba32                   IGNORED
include_tree                  IGNORED
=============================================== 1 failed, 0 succeeded in 00:00:05.443 ===============================================
The terminal process terminated with exit code: 1
Terminal will be reused by tasks, press any key to close it.
Dependency Graph
|-- <Servo> 1.0.0
|-- <SailfishLCD>
for Z2."
==================================================== [FAILED] Took 6.02 seconds ====================================================
rambo                         IGNORED
melzi                         IGNORED
DUE                           IGNORED
DUE_USB                       IGNORED
DUE_debug                     IGNORED
LPC1768                       IGNORED
LPC1769                       FAILED    00:00:06.019
STM32F103RC                   IGNORED
STM32F103RE                   IGNORED
STM32F4                       IGNORED
STM32F7                       IGNORED
ARMED                         IGNORED
mks_robin                     IGNORED
chitu_f103                    IGNORED
FLYF407ZG                     IGNORED
FYSETC_S6                     IGNORED
teensy31                      IGNORED
teensy35                      IGNORED
esp32                         IGNORED
mks_rumba32                   IGNORED
=============================================== 1 failed, 0 succeeded in 00:00:06.019 ===============================================
Il y a 17 heures, Guillaume3D a dit :
Réponse courte: oui.gif.fe867e4cc9d5fab4e655d0649b194dd3.gif  rire_1.gif.3f5e76dc23e8dc86ea9ebeb38ef14ae0.gif
Après pas mal de déboires, j'ai réussis à avoir quelque chose. J'ai du télécharger la version github de Marlin publié par BigreeTech car la version officiel de marlin n'avait pas inclus correctement la SKR 1.4 TT. D'ailleur la versions de marlin pour la SKR 1.4 Turbo est sortie qu'il n'y a de très peu de temps 🙂
Comme je suis un Dieu vivant, pour l'instant tout se compile et tout à l'air de fonctionner. Je viens de commander la carte (SKR v1.4 Turbo 120mhz) et je l'attend pour faire mes premiers tests 😄
Modifié (le) par Guillaume3D
  • 3 months later...
Le 10/02/2020 at 18:15, Guillaume3D a dit :
bonjour, tu as reçu ta carte ? Tu peux nous dire si tout est ok?
il y a 57 minutes, keflo a dit :
Oui nickel 😉
  • 4 weeks later...
Bonjour, j'espère ne pas arriver trop tard et que les souvenirs de la config des TMC 2208 sur une BTT SKR 1.4 sont encore frais.
J'en ai installé des DIY V3 sur ma Ender 3, sous Marlin 2.0 et les 4 moteurs fonctionnent comme attendu MAIS j'ai le message"TMC connection error" qui s'affiche à l'écran. Par ailleurs le code M122 laisse penser que la com UART ne se fait pas du tout :
Driver registers:
		X	0x00:00:00:00	 Bad response!
		Y	0x00:00:00:00	 Bad response!
		Z	0x00:00:00:00	 Bad response!
		E	0x00:00:00:00	 Bad response!
Testing X connection... Error: All LOW
Testing Y connection... Error: All LOW
Testing Z connection... Error: All LOW
Testing E connection... Error: All LOW
Voici la configuration de la carte :
FGP642EK6WZYS9A.LARGE.jpg?auto=webp&fram
J'ai également réalisé la soudure en J2 (first method).
La carte est alimentée en VDD et non USB.
Je dois dire qu'un détail doit m’échapper mais impossible de mettre la main dessus. Je suis preneur de toute idée qui pourrait débloquer ma situation.
Si besoin, j'ai joint ma config Marlin.
Configuration.h Configuration_adv.h
Modifié (le) par Ne0tuX
Problème résolu en soudant non pas via la méthode 1 ni la méthode 2, mais en soudant les 3 pins ensemble + jumper sur les pins PDN/UART sur le dessus des drivers. Si ça ne dérange pas je laisse mon message pour future référence.
Tiens @Ne0tuX je suis exactement dans le même cas que toi ! Je me retrouve avec le défaut TMC connection error ... aurais tu une photo de la soudure que tu a faites s'il te plait ?
EDIT c'est bon j'ai suivi ton idée de connecté via la partie haute du driver les deux pins UART via un jumper + soudure first méthod et les X et Y sont passé en connexion OK ! 😁 je m'en vais faire de même pour le Z et le E et j'aurais bien avancé ! 🙂
Modifié (le) par Oze
Tiens voilà un nouveau problème ! maintenant que les TMC fonctionne sous UART et qu'il n'y a plus de défaut à l'écran c'est le déplacement des axes qui est étrange...
Avant soudure comme le modèle 1 et ajout du jumper pour lié les deux pins du haut du driver quand je demandais un déplacement de 10mm la machine en faisait 20/25.. Mais maintenant quand je demande 10mm elle se déplace de 2mm 🙄
Pourtant sous config.h j'ai bien 80 de default_axis_steps_per_unit et je ne sais pas si cela a un rapport mais sous config_adv.h dans trinamic_config mais drivers sont réglé comme dans la vidéo de Edward Braiman donc 16 microsteps et X/Y_current 700
Je veux bien essayer d'augmenter la valeur de steps_per_unit x4 mais je ne suis pas sur que ce soit la solution... il doit y avoir un problème car 80 pour le X et le Y sont des valeurs "standard" sur de nombreuses machines
Une idée ?
