Sinon, j'ai encore un truc qui ne va pas avec l'écran...
Bon, maintenant, j'ai les retours de temp.
Mais j'ai pas le retour de la vitesse du ventilo ni de la hauteur de couche... Et ça, je ne l'ai pas vu dans la config.ini de l'écran.
Je vais la mettre en ligne en entier, ça aidera ceux qui savent et ça montrera à quoi ça ressemble à ceux qui ne connaissent pas...
#### Default Config file for BigTreeTech TFT Controllers
# BIGTREE_TFT35_V1_1 / BIGTREE_TFT35_V1_2    / BIGTREE_TFT35_V2_0
# BIGTREE_TFT35_V3_0 / BIGTREE_TFT35_E3_V3_0 / BIGTREE_TFT28_V1_0
# BIGTREE_TFT28_V3_0 / BIGTREE_TFT24_V1_1    / MKS_32_V1_4
# Firmware Source: https://github.com/bigtreetech/BIGTREETECH-TouchScreenFirmware
# Supported Marlin Firmware Version
#  Minimum Marlin Firmware Version: Bugfix-2.0.x
#  Distribution date: 2020-05-12
#  Source: https://github.com/MarlinFirmware/Marlin/tree/bugfix-2.0.x
# General Settings
#### UNIFIED MENU / CLASSIC MENU
# Select a UI Menu flavour
# Options: [Unified Menu: 1, Classic Menu: 0]
unified_menu:1
#### Baudrate
# Options: [2400: 0, 9600: 1, 19200: 2, 38400: 3, 57600: 4, 115200: 5, 250000: 6, 500000: 7, 1000000: 8]
baudrate:5
#### Default Touch Mode Language
# Select the language to display on the LCD while in Touch Mode.
# Options: [0: ENGLISH,   1: CHINESE,  2: RUSSIAN,  3: JAPANESE,  4: ARMENIAN,
#           5: GERMAN,    6: CZECH,    7: SPAIN,    8: FRENCH,    9: PORTUGUESE,
#          10: ITALIAN,  11: POLISH,  12: SLOVAK,  13: DUTCH,    14: HUNGARIAN]
language:8
#### Default Touch Mode Color Options
# Options: [0: WHITE,   1: BLACK,    2: RED,    3: GREEN,   4: BLUE:,      5: CYAN,        6: MAGENTA,  7: YELLOW,
#           8: ORANGE,  9: PURPLE,  10: LIME,  11: BROWN,  12: DARKBLUE,  13: DARKGREEN,  14: GRAY,    15: DARKGRAY]
# Title background color
title_back_color:1
#Background color
background_color:1
#Font foreground color
font_color:0
#Reminder font color, such as: "No print attached", "Busy processing", etc.
reminder_color:2
#Volume status/reminder font color, such as: "Card inserted", "Card removed"
volume_status_color:5
#Backgroud color for X Y Z position display in Status Screen.
status_xyz_bg_color:15
#List View Border Color
list_border_color:15
#List View button background color
list_button_bg_color:15
#### Rotate UI 180 degrees
# Options: [enable: 1, disable: 0]
rotate_ui:0
#### Show or hide Temperature ACK in Gcode Terminal
# Options: [Show: 1, Hide: 0]
terminal_ack:0
#### invert X axis button function in Move menu to match move buttons to actual axis
# Invert Axis format      [ X<option> Y<option> Z<option> E<option>]
invert_axis:X0 Y0 Z0
#### Persistent temperature info
# show persistent temperature info on all menu screens
persistent_info:1
#### File List Mode
# show file as list
files_list_mode:1
# Marlin Mode Settings (Only for TFT35_V3.0/ TFT24_V1.1/ TFT28V3.0)
#### Default Mode
# Options: [0:Touch Mode, 1: Marlin Mode]
default_mode:0
#### Keep Serial Always ON
# Keep UART (Serial communication) alive in Marlin Mode
# Allow seamless OctoPrint UART connection to the TFT's UART/serial expansion port no matter which mode the TFT is in.
# Options: [0: Disabled, 1: Enabled]
serial_always_on:0
#### Default Marlin Mode Background & Font Color Options
# Options: [ WHITE: 0,  BLACK: 1,  RED: 2,  GREEN: 3,      BLUE: 4,       CYAN: 5,  MAGENTA: 6,    YELLOW: 7,
#           ORANGE: 8, PURPLE: 9, LIME: 10, BROWN: 11, DARKBLUE: 12, DARKGREEN: 13,    GRAY: 14, DARKGRAY: 15]
marlin_bg_color:1
marlin_fn_color:8
#### Marlin Mode show title
marlin_show_title:1
# Run Marlin Mode in Fullscreen
# Options: [enable: 1, disable: 0] [Disabled. RECOMMENDED FOR TFT24]
marlin_fullscreen:0
#### Text displayed at the top of the TFT in Marlin Mode.
marlin_title:LCD12864 Simulator
# Printer / Machine Settings
#### Hotend Count
# Options: [1 to 6]
hotend_count:1
#### Extruder Count
# Options: [1 to 6]
ext_count:1
#### Fan Count
# Options: [1 to 6]
fan_count:1
#### Bed / Extruder Maximum Temperatures
# format [max_temp: BED:<max temp> T0:<max temp> T1:<max temp> T2:<max temp> T3:<max temp> T4:<max temp> T5:<max temp>]
max_temp:BED:150 T0:275 T1:275 T2:275 T3:275 T4:275 T5:275
#### Cold Extrusion Minimum Temperature
min_temp:180
#### Fan Maximum PWM speed (0 to 255)
# format [fan_max: F0:<max temp> F1:<max temp> F2:<max temp> F3:<max temp> F4:<max temp> F5:<max temp>]
fan_max:F0:255 F1:255 F2:255 F3:255 F4:255 F5:255
#### Machine Size / Build Area (mm)
# Options: [X Axis: X, Y Axis: Y, Z Axis: Z]
# minimum possible value: -2000, maximum possible value: 2000
# minimum size limit format [size_min: X<minimum distance> Y<minimum distance> Z<minimum distance>]
# maximum size limit format [size_max: X<maximum distance> Y<maximum distance> Z<maximum distance>]
size_min:X0 Y0 Z0
size_max:X235 Y235 Z250
#### default Move Speeds (mm/min)
# Options: [Slow: S, Normal: N, Fast: F]
# format   [move_speed: S<feedrate mm/min> N<feedrate mm/min> F<feedrate mm/min>]
move_speed:S1000 N3000 F5000
#### default Extruder Speeds (mm/min)
# format   [ext_speed: S<feedrate mm/min> N<feedrate mm/min> F<feedrate mm/min>]
ext_speed:S60 N600 F1200
#### Auto Save Load Leveling Data
# The TFT will auto-detect if Auto Bed Level is available.
# Enable this will send "M500" after "G29" to store leveling value
# and send "M420 S1" to enable leveling state after startup
auto_load_leveling:1
#### Onboard / Printer SD Card Support
# On Marlin Firmware, The TFT will auto detect Onboard SD Card
# Auto-detect is not available for other firmwares like Smoothieware
#Options: [enable: 1, disable: 0, auto-detect: 2]
onboard_sd_support:1
#### M27 / Printing status refresh time (this will be used if SD_AUTOREPORT is not detected by the TFT)
M27_refresh_time:3
#### M27 always active - keep polling M27 even if not printing
M27_always_active:1
#### Long File Names Support
# On Marlin Firmware, The TFT will autodetect Long File Name supported
long_filename_support:2
#### Show Fan Speed as Percentage
fan_speed_percent:1
#### Pause Settings
# position & Lengths in mm, Feedrates in mm/min
# minimum possible value: 0, maximum possible value: 2000
# Pause retract distance format [pause_retract: R<retract length> P<Resume Purge length>]
# Pause XY position format      [pause_pos: X<position in mm> Y<position in mm>]
# Pause Z raise format          [pause_z_raise: Z<distance in mm>]
# Pause feed Rate # format      [ X<feedrate mm/min> Y<feedrate mm/min> Z<feedrate mm/min> E<feedrate mm/min>]
pause_retract:R15 P16
pause_pos:X10 Y10
pause_z_raise:20
pause_feedrate:X6000 Y6000 Z6000 E600
### Manual Level Points Edge distance (mm)
# distance in mm, Feedrates in mm/min
# Leveling Edge distance format  [level_edge_distance: <distance from edge in mm>]
# Leveling Z Position format     [level_z_pos: Z<position in mm>]
# Leveling Z raise format        [level_z_raise: Z<distance in mm>]
# Leveling feed Rate format      [ X<feedrate mm/min> Y<feedrate mm/min> Z<feedrate mm/min>]
level_edge_distance:20
level_z_pos:0.2
level_z_raise:10
level_feedrate:X6000 Y6000 Z6000
#### Preheat Temperature
# Maximum Filament name length 7 characters
# If default names are changed, make sure to change Icons to match the names
#format [T<hotend temp> B<bed temp>]
preheat_name1:PLA
preheat_temp1:T200 B60
preheat_name2:PETG
preheat_temp2:T200 B60
preheat_name3:ABS
preheat_temp3:T230 B90
# Power Supply Settings (if connected to TFT Controller)
#### Default Power Supply Mode
# Options: [OFF: 0, ON: 1: Auto:2]
ps_on:0
#### Power Supply Active HIGH Settings
# Options: [HIGH: 1, LOW: 0]
ps_on_active_high:1
#### Maximum hot-end temperature of automatic shut down after printing (only if auto power is enabled)
# wait for the hot-end temperature to be lower than this value, then turn off the power automatically
auto_shutdown_temp:50
# Filament Runout Settings (if connected to TFT Controller)
#### Default FIlament Sensor
# Options: [NONE: 0, Normal: 1, SMART: 2]
fil_runout:0
#### Filament runout inverting - invert the logic of the sensor.
# Options: [true: 1, false: 0]
fil_runout_inverting:1
#### filament noise threshold  - Pause print when filament runout is detected for this time period in (ms).
# time duration in ms
fil_noise_threshold:100
#### Smart filament runout detection
# For use with an encoder disc that toggles runout pin as filament moves
fil_runout_distance:7
# Power Loss Recovery & BTT UPS Settings (if connected to TFT Controller)
#### Home before Power Loss recovery
pl_recovery_home:0
#### Power Loss Z raise (mm)
# Raise Z axis on resume (on power loss with UPS)
pl_z_raise:0
#### Enable BTT UPS
btt_mini_ups:0
# Other device-specific settings
#### Buzzer / sound
buzzer:1
#### Knob Led Color (only for TFT35 E3.0)
#Options: [LED_OFF: 0, LED_WHITE: 1, LED_RED: 2, LED_ORANGE: 3, LED_YELLOW: 4, LED_GREEN: 5, LED_BLUE: 6, LED_INDIGO: 7, LED_VIOLET: 8]
knob_led_color:0
#### Default LCD Brightness levels (only for TFT35v3.0 & TFT28v3.0)
# Options: [(low) 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 (full)]
lcd_brightness:10
lcd_idle_brightness:5
#### Default LCD idle time (only for TFT35v3.0 & TFT28v3.0)
# Options [Off: 0, 5Sec: 1, 10Sec: 2, 30sec: 3, 1min: 4, 2min: 5, 5min: 6, 10min: 7]
lcd_idle_delay:4
# Custom G-Code Commands (up to 15 custom G-code)
#### To enable a custom Command:
# Remove '#' at the begining custom commands label & gcode.
#### To disable a custom Command:
# Add '#' at the begining custom commands label & gcode.
# if the values are left blank then default name and G-code will be used
# Options: [Label maximum length: 24 characters, G-code Maximum length 70 characters]
custom_label_1:Disable steppers
custom_gcode_1:M84\n
custom_label_2:Init sd card
custom_gcode_2:G28\nG29\nG0\n
custom_label_3:Release sd card
custom_gcode_3:M22\n
custom_label_4:restore leveling
custom_gcode_4:M420 S1\n
custom_label_5:Save to EEPROM
custom_gcode_5:M500\n
custom_label_6:restore from EEPROM
custom_gcode_6:M501\n
custom_label_7:EEPROM defaults
custom_gcode_7:M502\n
#custom_label_8:custom8
#custom_gcode_8:M105\n
#custom_label_9:custom9
#custom_gcode_9:M105\n
#custom_label_10:custom10
#custom_gcode_10:M105\n
#custom_label_11:custom11
#custom_gcode_11:M105\n
#custom_label_12:custom12
#custom_gcode_12:M105\n
#custom_label_13:custom13
#custom_gcode_13:M105\n
#custom_label_14:custom14
#custom_gcode_14:M105\n
#custom_label_15:custom15
#custom_gcode_15:M105\n
# Start, End & Cancel G-codes
#### Default Start Gcode Status
start_gcode_enabled:0
#### Default End Gcode Status
end_gcode_enabled:0
#### Default Cancel Gcode Status
cancel_gcode_enabled:0
#### Start G-code - run this G-code before starting print
# maximum length 50 characters
start_gcode:G28 XY R20\n
#### End G-code - run this G-code after finishing print
end_gcode:G90\nG1 E-4\nG92 E0\nM18\n
#### Cancel G-code - run this G-code after canceling print
cancel_gcode:G28 XY R10\n
Voilà, donc, si vous voyez quel paramètre il faut changer... Merci les gars 😉
Oui, je l'ai bien enregistré M500 via PRONTERFACE.
Pour faire plus simple je vous envoi la doc.
Tenez moi au jus et si quelqu'un a une réponse à mon problème car là encore je rame!!!
BLTOUCH FRED.txt
Salut Fred, et ben, c'est bien compliqué ton histoire !!! La vache 🙄
De mon côté, c’est beaucoup plus simple et rapide...
M502, M500.
G28
G0  Z0
G0 Z-1
G0 Z-1.2, etc...
M851 Z-xx.xx
M500
G29
Le réglage du offset est terminé 😉
Mon le Gcode de départ, je te donne le mien :
Custom Start G-code
G92 E0 ; Reset Extruder
G28 ; Home all axes
G29
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
Voilà, à toi de voir... 😉 il y a aussi la goutte de purge (2 lignes de purge pour l'extruder)
Sinon, j'ai pensé à toi hier soir, sur mon Ender3, avec la carte SKRmini E3 V1.2, rien ne s'allumé sauf le ventilo !!!
Le 3Dtouch était branché, mais non activé dans le FW (puisque je n'arrive pas a compiler pour cette carte). Et ben, j'ai débranché le 3Dtouch, et là, tout s'allume 😁
Modifié (le) par PLFmoto
J'ai encore fait plus complet avec le siens perso qui est certe un peu long mais plus précis.
Le nouveau réglage du Bed ( chaud 50° en ce qui me concerne)  par le bltouch a à mon sens, un réel intérêt  car le bed est en alu et sous l'effet de chaleur travaille. Testé et vérifié par mes soins!!! Plateau tout neuf rayé!!!
Je suis heureux de constater que nous ayons pu enfin y arriver comme quoi l'union fait la force et l'oignon la soupe!!! La persévérance, la réussite!
Je dirais même que certains sont des fous furieux! Attaquer un deuxième machine dans la foulée. Ben mon ga!!! tu vois à qui je fais allusion...
Je joint un petite vidéo de la bête qui travaille juste question de flatté mon ego!! Même si il y encore du peaufinage à effectuer.
Merci à tous, merci à toi.
Je reste encore avec vous car je sens bien que je vais devoir encore vous en......  un peu!
Fred
PS: Les vidéos ne fonctionnent pas! C'est le petit jésus qui m'a puni !!
il y a 49 minutes, fremel@wanadoo.fr a dit :
Fred
Tu fais allusion à qui ? je ne vois pas du tout... 🤔😄
Salut les guerriers!
Et oui c'est encore lui!!!
Ma question est simple je rencontre le même problème concernant les températures affichées sur l'écran  sur la page d'accueil. Lorsque j'allume l'imprimante, ils sont à zéro; lorsque l'imprimante est reliée à l'ordi elles passent à 26° ? J'ai effectué une tour de température avec cura et lors de l'impression l'écran n'affiche que la temp de départ.
Ma question est simple  malgré le fait que j'ai lu et relu le travail de PLF Moto, JE NE SAIS COMMENT ACCEDER AUX FICHIERS pour effectuer les changements nécessaires.
Vraiment désolé
Fred
J'ai trouvé désolé pour dérangement!!!
Merci et bonnes vacances pour ce qui auront cette chance
Fred
Salut Fred,
Alors, c'est assez simple...
Tu vas dans le répertoire ou tu as mis ton FW "BIGTREETECH-TouchScreenFirmware-master"
Tu ouvre le répertoire correspondant à ton écran TFT35, etc...
Tu ouvre ensuite le répertoire correspondant à ton "thème" d'affichage
Tu ouvres avec NotePad++ par exemple le fichier "Config"
Une fois ouvert, tu fais tes modifs :
persistent_info:0
Pour la température, mais tu peux aussi changer d'autres choses si tu le souhaite...
Ensuite, tu enregistres et tu mets sur ta carte SD (écran toujours hein...) Le fichier config + BIGTREE_TFT.... + le répertoire TFT35
Et tu lance la machine avec la SD dans l'écran... 😉
Il y a 6 heures, PLFmoto a dit :
Pas trop fort quand même et pas contre un mur si possible 😄
il y a 11 minutes, fran6p a dit :
Salut les hommes!
Désolé pour ce long silence mais j'étais en voyage.
Merci pour les conseils mais c'est trop tard! J'ai lancé l'imprimante et elle a pas aimé la porte! pas fou le mec sur le mur il n'y aurait plus rien rien! 🤪
Après de longs réglages sur cura et avec le PLA Eryone black,  je vous cache pas pas que je suis vraiment heureux c'est superbe plus rien à voir avec l'ancienne carte mère.
Pour info, j' utilise le G.Code de départ dans cura de PLF moto, oh le copieur!!!! Non il est très bien franchement!
Par contre je vous cache pas que le G.Code de fin d'origine CURA ne convient pas à l'imprimante. Je m'explique!!!!!!!
Lorsque l'impression est terminée j'ai à l'écran un message d'erreur IMPRESSION alors que l'impression en elle même est OK. Donc la température ne redescend pas pour le bed et la buse
Je dois interrompre l'impression via le menu de l'écran. Puis éteindre  et rallumer l'imprimante rapidement pour que la buse refroidisse normalement et avoir le plateau libre de tout mouvement.
J'ai tout repris à zéro firmware, réglage etc.... changement de G.Code de fin dans cura et rien ne change et le pire est à venir😂🤣
lorsque je veux effectuer une nouvelle impression,  fichier sur clé USB, là c'est la merde complète un coup c'est le home qui plante, quand il passe le G 29 fonctionne une fois sur deux.
Bon vous avez compris JE MERDE ENCORE et surtout je ne comprends pas la cause donc!!!
Firmware, G.code de fin, clé USB ou tout simplement un manque de cervelle?
Sérieusement je compte une fois de plus sur vous merci par avance😜
fred
ps: petite photo
J'ai pas du tout ce phénomène avec le Gcode de fin...
Tu imprime depuis quoi ? l'écran ou la CM ?
C'st quand même étrange que tes dysfonctionnements  soit aléatoire comme ça 🤔
Est-ce que tu veux faire un essais avec mon FW ? (avant que je le re-modifie pour le nouvel extruder)
OUI AVEC PLAISIR AU MOINS JE POURRAIS COMPARER AVEC LE MIEN
MERCI
J'imprime depuis l'écran soit puce soit USB
Après remise à zéro, chargement nouveau FW,  le retour home ce fait sur l'axe, X, Y, et au Z l'axe  il va bien au centre mais ne descend pas. Il reste sur place et le BLTouch  se trouve bien entendu en défaut car il palpe dans le vide.
Ce que je n'arrive pas à comprendre c'est pour quelle raison je suis parvenu à plusieurs reprises à tout faire fonctionner et que sans rien changer au FW cela ne fonctionne plus.
J'ai bien fait une commande M502 à chaque fois pour formater l'EEprom. Pour être certain de repartir à zéro correctement
Après ton M502, tu as bien fait un M500 ? sinon, ça ne fonctionne pas...
Tiens, voilà mes fichiers :
Configuration.h Configuration_adv.h
Merci pour les fichiers cool,
Oui j'ai suivi d'un M500
Je plonge le nez dedans et je te tiens informé
Oh rage, oh désespoir!
Salut, bon je ne comprends toujours rien.
Rien à faire toujours la même histoire un cou bon puis la suite ..... comme expliqué plus haut.
le retour home au démarrage ce fait pour l'axe X puis le Y et lorsque j'arrive au Z, il ne descend pas chercher le bed donc le BLTouch palpe dans le vide.
J'ai pris ligne par ligne ton config H et c'est la même chose que le mien.
Peux tu me communiquer ta méthode de calibrage du BLTouch après la mise en place d'un nouveau FW dés fois que ce serait là que je merde.
merci
Voici celui utilisé par mi
Instructions de décalage Z:
1. Imprimante 3D domestique
2. M851 Z0 - Réinitialiser le décalage Z0
3. M500 - Enregistrer les paramètres dans eeprom
4. M501 - Définir les paramètres actifs
5. M503 - Affichage des paramètres actifs
6. G28 Z - Axe Z d'origine
7. G1 F60 Z0 - Déplacez la buse sur le vrai décalage 0
8. M211 S0 - Désactiver les butées souples
9. Déplacez lentement la buse vers le lit jusqu'à ce que le papier puisse à peine bouger
10. Notez le Z sur l'écran de l'imprimante (prenez ce nombre et ajoutez la mesure de la feuille d'étalonnage ou du périphérique utilisé)
11. M851 Z X.XX (X.XX étant votre décalage z atteint)
12. M211 S1 - Activer les fins de course logicielles
13. M500 - Enregistrer les paramètres dans Eeprom
14. M501 - Définir les paramètres actifs
15. M503 - afficher les paramètres actuels
Heu, pourquoi ces lignes :
Avec ma version du Fw, pas besoin...
Tu as laissé tes endstop ? 🤔
Ma procédure :
M502
M501
M503
G28
G0 z0
G0 Z-1 etc...
M851 Z-xx.xx
M500
Cette ligne dans Config.H te permet de descendre en dessous du Z0
  //#define MIN_SOFTWARE_ENDSTOP_Z
Donc, pas besoin de désactiver quoi que ce soit... 😉
Pardonnes ma réponse si tardive j'avais la tête dans la machine
Je ne t'ai pas envoyé la bonne doc voici celle utilisée
Préparation:
1-       Après avoir flashé Marlin, sur le terminal on commence pour plus de sécurité  par un M502 (charger les réglages EEPROM d’origine)  puis M500 (enregistrer réglages dans l’EEPROM) puis, si on est un peu maniaque  comme moi un petit M501 (charger les données de l’EEPROM).
2-        M851 pour vérifier que l’offset est bien à 0 de base (si c’est le cas: parfait sinon on fait M851 Z0 puis M500)
3-        G28 puis G28 Z (homing des axes puis on se concentre sur le homing du Z)
4-        G1 F60 Z0 (on demande à l’imprimante de descendre à ce qu’elle pense être le 0 de l’axe Z)
5-        M211 S0 (on désactive le software endstop pour pouvoir régler notre offset du Z manuellement)
Réglage du Z Offset:
1-  On place notre feuille à papier (ou autre cale de 0.10mm environ)  sur le plateau et à l’aide de l’écran de l’imprimante (sur le Menu: Mouvement>Déplacer un axe> Déplacer Z)    on descend la buse 1mm par 1mm puis 0.1mm par 0.1mm jusqu’à ce qu’on sente un frottement sur la feuille de papier (le papier ne soit pas être coincé mais pas non plus trop libre).
2- Maintenant, on retourne sur la page d’accueil depuis l’écran LCD et on note la valeur du Z affiché (juste en dessous de l’icône qui ressemble à un ventilo sur la droite)
3- On soustrait 0.1mm (l’épaisseur de la feuille ou de la cale) à cette valeur (exemple: si on a Z -2.4 on obtiendra -2.5 ) et on utilise cette valeur pour régler l’offset    avec la commande M851 ZX.XX (dans mon exemple M851 Z-2.5)
4- On réactive le software endstop avec M211 S1 puis enregistre le tout avec M500 puis M501
5- On vérifie le Z-offset en envoyant G1 F60 Z0 (normalement on devrait se retrouver au « vrai »  0 du Z maintenant, c’est à dire l’épaisseur de votre cale entre la buse et le plateau)
Activation du nivellement avec le BL Touch:
1- On envoie un G28 (homing des axes)
2-  On envoie G29 (on lance la palpation du plateau avec et on attend la fin de la procédure – qui se termine lorsque la buse ne bouge plus)
3-  M420 S1 (on active le nivellement automatique avec les données que notre BL Touch vient de générer)
4- On sauvegarde avec M500 puis un petit M501 qui ne mange pas de pain et c’est fini!
Pour info j'ai tout recalibré mais en passant directement par Pronterface puis j'ai lancé une impression directement  de CURA en USB. Pour l'instant cela imprime j'attends la fin d'impression pour voir la réaction.
En ce qui concerne la ligne commande //#define MIN_SOFTWARE_ENDSTOP_Z  c'est bien ce que j'ai dans mon config H
Merci de l'info je vais donc supprimer cette commande dans dans la calibration du BLTouch.
Je te tiens informé de l'évolution et répondrais en direct à tes réponses car je reste devant l'ordi
Encore Merci
Ps: je suis indiscret mais tu roules avec quoi comme bécane?  En ce qui me concerne 600 GSR 😉
