le printer.cfg n'a pas changé
#    https://github.com/Klipper3d/klipper/blob/master/config/generic-bigtreetech-manta-m8p-v1.1.cfg
# set in /home/pi/printer_data/config/
# This file contains common pin mappings for the BIGTREETECH Manta M8P
# To use this config, the firmware should be compiled for the
# STM32G0B1 with a "8KiB bootloader" "8 MHz crystal"
# and "USB (on PA11/PA12)" or "CAN bus (on PD12/PD13)".
# See docs/Config_Reference.md for a description of parameters.
[stepper_x]		# <<< OK >>>
step_pin: PE2
dir_pin: PB4
enable_pin: !PC11
microsteps: 16
rotation_distance: 40
endstop_pin: ^PF3
position_endstop: 500	<<< MODIFIED
position_max: 500	<<< MODIFIED 485/235
homing_speed: 50
[stepper_y]		# <<< OK >>>
step_pin: PF12
dir_pin: PF11
enable_pin: !PB3
microsteps: 16
endstop_pin: ^PF4
position_endstop: 505	<<< MODIFIED 0
position_max: 505	<<< MODIFIED 485/235
homing_speed: 50
[stepper_z]		# <<< OK >>>
step_pin: PD7
dir_pin: !PD6
enable_pin: !PF10
microsteps: 16
endstop_pin: ^PF5
position_endstop: 0
position_max: 570	<<< MODIFIED 600/270
[stepper_z1]		# <<< OK >>>
step_pin: PD3		#PD7
dir_pin: !PD2		#!PD6
enable_pin: !PD5	#!PF10
microsteps: 16
#endstop_pin: ^PF5
position_endstop: 0
#position_max: 270	<<< MODIFIED
[stepper_z2]		# <<< OK >>>
step_pin: PC9		#PD7
dir_pin: !PC8		#!PD6
enable_pin: !PD1	#!PF10
microsteps: 16
#endstop_pin: ^PF5
position_endstop: 0
[stepper_z3]		# <<< OK >>>
step_pin: PA10		#PD7
dir_pin: !PA14		#!PD6
enable_pin: !PA15	#!PF10
microsteps: 16
#endstop_pin: ^PF5
position_endstop: 0
# Motor4
# The M8P only has 4 heater outputs which leaves an extra stepper
# This can be used for a second Z stepper, dual_carriage, extruder co-stepper,
# or other accesory such as an MMU
#[stepper_]
#step_pin: PD3
#dir_pin: PD2
#enable_pin: !PD5
#endstop_pin: PC0
[extruder]		# <<< OK >>>
step_pin: PD11		#PC9
dir_pin: PD9		#PC8
enable_pin: !PD15	#!PD1
microsteps: 32							# vs 16
rotation_distance: 22.0		#Bondtech 5mm Drive Gears	# 33.500 vs 22.6789511
full_steps_per_rotation:200
gear_ratio: 50:10
nozzle_diameter: 0.4
filament_diameter: 1.75
heater_pin: PE3 # HE0
sensor_type: Generic 3950		#EPCOS 100K B57560G104F		#<<<<<<<<<<<<<<<<<<<<< ? NTC 100K MGB18-104F39050L32
sensor_pin: PA1 # T0
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 250
#max_power: 1.0
#[filament_switch_sensor material_0]
#switch_pin: PC1
# Motor6
#[extruder1]
#step_pin: PA10
#dir_pin: PA14
#enable_pin: !PA15
	#heater_pin: PB5 # HE1
	#sensor_pin: PA2 # T1
#microsteps:16
endstop_pin: ^PF5
position_endstop: 0
position_max: 570
#[filament_switch_sensor material_1]
#switch_pin: PC2
# Motor7
#[extruder2]
#step_pin: PD11
#dir_pin: PD9
#enable_pin: !PD15
#heater_pin: PB6 # HE2
#sensor_pin: PA3 # T2
#microsteps:16
# Motor8
#[extruder3]
#step_pin: PD8
#dir_pin: PC6
#enable_pin: !PC7
#heater_pin: PE1 # HE3
#sensor_pin: PA4 # T3
#microsteps:16
[heater_bed]
heater_pin: PB7
sensor_type: Generic 3950			#<<<<<<<<<<<<<<<<<<<<< OK
sensor_pin: PA0 # TB
control: watermark
min_temp: 0
max_temp: 120
#max_power: 0.8
[fan]			# <<< OK >>>
pin: PE6	# PCB>PCF
[heater_fan fan1]
pin: PE0        # PCB>HEF
[heater_fan fan2]
pin: PC12       # Electronic x2
[heater_fan fan3]
pin: PE5	# Filtration x2
#[heater_fan fan4]
#pin: PE4      # Extraction
#[heater_fan fan5]
#pin: PB8
#tachometer_pin: PC14
#[heater_fan fan6]
#pin: PB9
#tachometer_pin: PC15
#[heater_fan SoC_fan]
#pin: CB1:gpio79
#pin: RPI:gpio26
[mcu]	#get serial in PutTY with 'ls /dev/serial/by-id/*'
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_2D0016000D504B4633373520-if00		#OK
[printer]	# <<< OK >>>
kinematics: corexy
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
# TMC2209 configuration
[tmc2209 stepper_x]    # vs [tmc2226 stepper_x]
uart_pin: PC10
#diag_pin: PF3
run_current: 0.800
stealthchop_threshold: 0
interpolate: False
[tmc2209 stepper_y]    # vs [tmc2226 stepper_y]
uart_pin: PF13
#diag_pin: PF4
run_current: 0.800
interpolate: False
[tmc2209 stepper_z]    # vs [tmc2226 stepper_z]
uart_pin: PD9		#PF9
#diag_pin: PF5
run_current: 0.650
interpolate: False
[tmc2209 stepper_z1]    # vs [tmc2226 stepper_z]
uart_pin: PD4		#PF9
#diag_pin: PF5
run_current: 0.650
interpolate: False
[tmc2209 stepper_z2]    # vs [tmc2226 stepper_z]
uart_pin: PD0		#PF9
#diag_pin: PF5
run_current: 0.650
interpolate: False
[tmc2209 stepper_z3]    # vs [tmc2226 stepper_z]
uart_pin: PF8		#PF9
#diag_pin: PF5
run_current: 0.650
interpolate: False
#[tmc2209 stepper_]    # vs [tmc2226 stepper_]
#uart_pin: PD4
##diag_pin: PC0
#run_current: 0.650
#stealthchop_threshold: 0
interpolate: False
[tmc2209 extruder]    # vs [tmc2226 extruder]		?
uart_pin: PD14		#PD0
run_current: 0.500	#0.800
interpolate: False
#[tmc2209 extruder1]    # vs [tmc2226 extruder1]
#uart_pin: PF8
#run_current: 0.800
#interpolate: False
#[tmc2209 extruder2]    # vs [tmc2226 extruder2]
#uart_pin: PD14
#run_current: 0.800
#interpolate: False
#[tmc2209 extruder3]    # vs [tmc2226 extruder3]
#uart_pin: PD10
#run_current: 0.800
#interpolate: False
# TMC2130 configuration
#[tmc2130 stepper_x]
#cs_pin: PC10
#spi_bus: spi1
##diag1_pin: PF3
#run_current: 0.800
#stealthchop_threshold: 999999
#[tmc2130 stepper_y]
#cs_pin: PF13
#spi_bus: spi1
##diag1_pin: PF4
#run_current: 0.800
#[tmc2130 stepper_z]
#cs_pin: PF9
#spi_bus: spi1
##diag1_pin: PF5
#run_current: 0.650
#[tmc2130 stepper_]
#cs_pin: PD4
#spi_bus: spi1
##diag1_pin: PC0
#run_current: 0.800
#[tmc2130 extruder]
#cs_pin: PD0
#spi_bus: spi1
#run_current: 0.800
#[tmc2130 extruder1]
#cs_pin: PF8
#spi_bus: spi1
#run_current: 0.800
#[tmc2130 extruder2]
#cs_pin: PD14
#spi_bus: spi1
#run_current: 0.800
#[tmc2130 extruder3]
#cs_pin: PD10
#spi_bus: spi1
#run_current: 0.800
[board_pins]			# <<< OK >>>
aliases:
    # EXP1 header
    EXP1_1=PE9, EXP1_2=PE10,
    EXP1_3=PE11, EXP1_4=PE12,
    EXP1_5=PE13, EXP1_6=PE14,    # Slot in the socket on this side
    EXP1_7=PE15, EXP1_8=PB10,
    EXP1_9=<GND>, EXP1_10=<5V>,
    # EXP2 header
    EXP2_1=PB14, EXP2_2=PB13,
    EXP2_3=PF7, EXP2_4=PB12,
    EXP2_5=PE7, EXP2_6=PB11,      # Slot in the socket on this side
    EXP2_7=PE8, EXP2_8=<RST>,
    EXP2_9=<GND>, EXP2_10=<NC>
## See the sample-lcd.cfg file for definitions of common LCD displays in /home/pi/klipper/config/ .
## Fysetc Mini 12864Panel v2.1 (with neopixel backlight leds)
#[display]
#lcd_type: uc1701
#cs_pin: EXP1_3
#a0_pin: EXP1_4
#rst_pin: EXP1_5
#contrast: 63
#encoder_pins: ^EXP2_5, ^EXP2_3
#click_pin: ^!EXP1_2
### Some micro-controller boards may require an spi bus to be specified:
##spi_bus: spi
### Alternatively, some micro-controller boards may work with software spi:
##spi_software_miso_pin: EXP2_1
##spi_software_mosi_pin: EXP2_6
##spi_software_sclk_pin: EXP2_2
#[output_pin beeper]
#pin: EXP1_1
#[neopixel fysetc_mini12864]
#pin: EXP1_6
#chain_count: 3
#color_order: RGB
#initial_RED: 0.4
#initial_GREEN: 0.4
#initial_BLUE: 0.4
[bed_mesh]
mesh_min: 40, 40
mesh_max: 460,460
[quad_gantry_level]
gantry_corners:
#   A newline separated list of X, Y coordinates describing the two
#   opposing corners of the gantry. The first entry corresponds to Z,
#   the second to Z2. This parameter must be provided.
-60,-10
560, 570
#   A newline separated list of four X, Y points that should be probed
#   during a QUAD_GANTRY_LEVEL command. Order of the locations is
#   important, and should correspond to Z, Z1, Z2, and Z3 location in
#   order. This parameter must be provided. For maximum accuracy,
#   ensure your probe offsets are configured.
50,25
50,425
450,425
450,25
#[bltouch]
#sensor_pin: PB2
#control_pin: PB1
# Proximity switch		# <<< OK >>>
[probe]
pin: PF6
z_offset: 0	#probe to bed
#[output_pin ps_on_pin]
#pin: PC3
#[output_pin pc13_pin]
#pin: PC13
#[neopixel my_neopixel_1]
#pin: PA9
[neopixel my_neopixel_2]	# <<< OK >>>
pin: PB15
#[hall_filament_width_sensor]	# ??? PF3/PF4 ([stepper_x]/[stepper_y]) ???
#adc1: PC5
#adc2: PB0
[filament_motion_sensor]¶
# Capteur de mouvement de filament.
# Prise en charge de la détection de présence et déplacement du filament à l'aide d'un encodeur basculant la broche de sortie
# pendant le mouvement du filament dans le capteur.
[filament_motion_sensor my_sensor]
detection_length: 7.0
#   La longueur minimale du filament tiré à travers le capteur déclenchant
#   un changement d'état sur la broche de commutation.
#   La valeur par défaut est 7 mm.
extruder: extruder
#   Le nom de la section de l'extrudeuse à laquelle ce capteur est associé.
#   Ce paramètre doit être fourni.
switch_pin: PC5
#pause_on_runout:
#runout_gcode:
#insert_gcode:
#event_delay:
#pause_delay:
#   Voir la section "filament_switch_sensor" pour une description des
#   paramètres ci-dessus.
#[adxl345]
#cs_pin: PC4			# OK
#spi_bus: spi1			# ???
il y a 4 minutes, jpeg a dit :
[bed_mesh]
speed: 300
horizontal_move_z: 10
mesh_min: 40, 40
mesh_max: 460,460
fade_start: 0.6
fade_end: 10.0
probe_count: 5,5
algorithm: bicubic
relative_reference_index: 12 # il faut le changer pour les nouvelles version de klipper mais je ne l'ai pas encore fait ...
pour le qgl (il manque quelques infos et les commentaires sont en dehors des infos :
[quad_gantry_level]
gantry_corners:
-60,-10
560, 570
50,25
50,425
450,425
450,25
speed: 100
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
@Savate
L'erreur reste la même après correction du printer.cfg
redémarrage de l'imprimante et de l'interface klipper.
Modifié (le) par jpeg
Il y a 8 heures, jpeg a dit :
la partie
a des caractères bizarres à la fin qui ne doivent pas plaire à Klipper
@Savate
Effectivement mais après correction cela n'a rien changé mais cela m'a mis la puce à l'oreille
et j'ai modifié manuellement les paramètres de [quad_gantry_level]
afin de m'assurer qu'aucun caractère masqué ne se trouvait en début ou en fin de ligne
et bingo, le message a changé en
rapport de Klipper : ERREUR
Impossible d'ouvrir le fichier de configuration /home/pi/printer_data/config/printer.cfg
Il me reste donc à modifier toutes les lignes de la même manière 😒
il y a une heure, jpeg a dit :
Si tu édite sur le pc, fais le avec notepad exclusivement (ou notepad++)
Je l'ai édité avec WinSCP (encodage 1252-ANSI).
J'ai commenté la section [filament_motion_sensor my_sensor] puisque le détecteur n'est pas encore installé
il y a 17 minutes, jpeg a dit :
ça marche aussi 🙂
j'aime bien avoir une copie en local ... au cas ou 🙂
@Savate
Je ne travaille que sur la copie en local avant d'écraser celle de la voron.
Finalement problème sans solution.
J'ai édité le fichier avec Notepad++ afin d'être sur qu'aucun caractère exotique ne trainait
(j'ai même poussé le vice jusqu'à remplacer les tabulations par des espaces).
J'ai testé les syntaxes de gear_ration avec et sans guillemets - rien n'y fait.
J'en ai même profité pour réorganiser les sections dans l'ordre de la doc.
Les voyants d'état de la Manta s'alument respectivement
Vert(ACT) fixe
Vert fixe et rouge(Power) fixe
Vert clignotant et rouge fixe
puis
Rouge fixe
puis
Rouge fixe etc
État Clipper : Déconnecter
J'ai joint le fichier final.
printer.cfg.txt
Il semble qu'il y ait des erreurs dans klipper.
Ci-joint le fichier klippy.log
klippy.log.txt
il y a 13 minutes, jpeg a dit :
il n'arrive pas jusqu'à la manta, il ne démarre même pas.
Il manque les macros dans ton fichier printer.cfg (mais ça ne doit pas l'empêcher de démarrer)
ton printer.cfg est bien dans le répertoire /home/pi/printer_data/config/printer.cfg ?
J'ai rajouté la fin du fichier et les macros (a reprendre, ce sont juste des exemples)
printer.txt
@Savate
Oui, le printer.cfg est bien situé.
Concernant l'absence des macros, j'imagine mal que cela empêche le chargement du fichier config.
Je rajoute, des fois que, toutefois, il n'y a pas un blème avec les «;» comme caractère de mise en commentaire ?
[gcode_macro PRINT_START]
#   Use PRINT_START for the slicer starting script - please customise for your slicer of choice
gcode:
    G32                            ; home all axes
    G1 Z20 F3000                   ; move nozzle away from bed
[gcode_macro PRINT_END]
#   Use PRINT_END for the slicer ending script - please customise for your slicer of choice
gcode:
    M400                           ; wait for buffer to clear
    G92 E0                         ; zero the extruder
    G1 E-10.0 F3600                ; retract filament
    G91                            ; relative positioning
    G0 Z1.00 X20.0 Y20.0 F20000    ; move nozzle to remove stringing
    TURN_OFF_HEATERS
    M107                           ; turn off fan
    G1 Z2 F3000                    ; move nozzle up 2mm
    G90                            ; absolute positioning
    G0  X125 Y250 F3600            ; park nozzle at rear
    #BED_MESH_CLEAR
il y a 7 minutes, jpeg a dit :
non, ce sont des commentaires dans la partie GCODE.
L'ajout de la partie gcode ne pose pas de problème si la machine est encore sur le dos quand elle redémarre ?
il y a 49 minutes, jpeg a dit :
non, ça marche dans toutes les positions 🙂
@Savate
Inchangé
Les dernières lignes de moonraker.log
**User=pi
2023-10-01 15:22:09,756 [server.py:add_log_rollover_item()] - Klipper Version: v0.11.0-205-g5f0d252b
2023-10-01 15:22:09,762 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/info
2023-10-01 15:22:09,763 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.info
2023-10-01 15:22:09,763 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/emergency_stop
2023-10-01 15:22:09,763 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.emergency_stop
2023-10-01 15:22:09,764 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/gcode/help
2023-10-01 15:22:09,764 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.gcode.help
2023-10-01 15:22:09,764 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/gcode/script
2023-10-01 15:22:09,764 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.gcode.script
2023-10-01 15:22:09,764 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/gcode/restart
2023-10-01 15:22:09,765 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.gcode.restart
2023-10-01 15:22:09,765 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/gcode/firmware_restart
2023-10-01 15:22:09,765 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.gcode.firmware_restart
2023-10-01 15:22:09,765 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/objects/list
2023-10-01 15:22:09,766 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.objects.list
2023-10-01 15:22:09,766 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/objects/query
2023-10-01 15:22:09,766 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.objects.query
2023-10-01 15:22:09,766 [app.py:register_remote_handler()] - Registering HTTP endpoint: (GET POST) /printer/objects/subscribe
2023-10-01 15:22:09,767 [websockets.py:register_api_handler()] - Registering Websocket JSON-RPC methods: printer.objects.subscribe
2023-10-01 15:22:09,771 [klippy_connection.py:_request_initial_subscriptions()] - Webhooks Subscribed
2023-10-01 15:22:09,773 [klippy_connection.py:_request_initial_subscriptions()] - GCode Output Subscribed
2023-10-01 15:22:09,775 [klippy_connection.py:_check_ready()] -
Unable to open config file /home/pi/printer_data/config/printer.cfg
C'est bizarre,
Essaye un printer.cfg minimaliste avec juste la section [mcu] et la section [printer]
@Savate
J'ai pratiqué jusqu'à stepper_Z ...
et j'ai eu l'affichage d'un nouveau message (orange)
qui m'énonce les sections et surtout spécifie
Soyez sûr d'avoir inclus "mainsail.cfg" dans votre fichier "printer.cfg"
J'ai un lien vers mainsail.cfg dans le même répertoire et c'est tout - rien qui fasse référence à ce fichier dans printer.cfg
Dois-je ajouter une section [include mainsail.cfg] ?
il y a 31 minutes, jpeg a dit :
je n'utilise mainsall que sur les V0 et je n'ai pas de include "mainsall.cfg" dans mes printer.cfg
vérifie juste que ton mainsall.cfg est bien renseigné
il y a 24 minutes, Savate a dit :
tu peux préciser ?
Sinon, dernier messager
rapport de Klipper: SHUTDOWN
MCU 'mcu' shutdown: ADC out of range
This generally occurs when a heater temperature exceeds
its configured min_temp or max_temp.
Once the underlying issue is corrected, use the
"FIRMWARE_RESTART" command to reset the firmware, reload the
config, and restart the host software.
Printer is shutdown
[extruder]
min_temp: 0
max_temp: 250
[heater_bed]
control: watermark
min_temp: 0
max_temp: 120
il y a 18 minutes, jpeg a dit :
rien de grave, soit le pin de capteur du bed ou de l'extrudeur n'est pas le bon, soit les thermistances ne sont pas branchées (-250 en min permet de faire sauter le problème)
@Savate
Effectivement, le -250 a résolu le problème mais pas le reste ;(
Si je ne mets pas la section [quad_gantry_level], et que j'ajoute une section include mainsail.cfg]
tout rentre dans l'ordre et j'arrive sur l'interface klipper mais dès que je l'ajoute
sans gantry_corners ou points, il me les réclame
et avec, j'ai toujours l'erreur.
Curieusement, j'ai remarqué que le message d'erreur change si je place la 1ère valeur sur la même ligne que l'entrée
50,425
450,425
450,25
ne signale plus d'erreur sur le 1er X, Y ( 50,25) !
de plus, selon qu'il y a ou non un espace après la virgule, le msg d'erreur supprime la virgule
=> problème de gestion des erreurs dans klipper ???
Euréka 😅
Il faut absolument un espace avant la 1ère valeur
gantry_corners:
 -60, -10
 560, 570
et
  50,  425
 450,  425
 450,   25
fonctionne
il y a 5 minutes, jpeg a dit :
oui, mais non, il ne faut pas 🙂
Référence de configuration - Documentation Klipper (klipper3d.org)
un essai simple, si tu rajoutes cette partie de config (même si elle ne correspond pas à ton imprimante, elle est censée fonctionner sans soucis)
#     Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
[safe_z_home]
##    XY Location of the Z Endstop Switch
##    Update -10,-10 to the XY coordinates of your endstop pin
##    (such as 157,305) after going through Z Endstop Pin
##    Location Definition step.
home_xy_position:234,355
speed:100
z_hop:10
[quad_gantry_level]
##    Use QUAD_GANTRY_LEVEL to level a gantry.
##    Min & Max gantry corners - measure from nozzle at MIN (0,0) and
##    MAX (250, 250), (300,300), or (350,350) depending on your printer size
##    to respective belt positions
##    Gantry Corners for 350mm Build
##    Uncomment for 350mm build
gantry_corners:
    -60,-10
    410,420
##    Probe points
    50,25
    50,275
    300,275
    300,25
speed: 100
retries: 5
max_adjust: 10
Tu n'as pas du lire la MAJ du précédent message qui a été fusionnée
Euréka 😅
gantry_corners:
 -60, -10
 560, 570
et
  50,  425
 450,  425
 450,   25
fonctionne
L'absence d'espace en début des jeux de valeurs plante Klipper
@Savate
Y a encore du taf 🙂
Quand j'envoie un G28 via klipper, j'ai une erreur qui est levée :
Unable to read tmc uart 'stepper_x' register IFCNT
Printer is shutdown
à l’instant, jpeg a dit :
tu as bien testé tous tes moteurs avant ?
Initial Startup | Voron Documentation (vorondesign.com)
