j'ai relancé la Box, j'ai relancé le raspberry.
quand je veux faire la MàJ de Klipper j'ai toujours le message d'erreur:
fatal: unable to access 'https://github.com/Klipper3d/klipper.git/': Failed to connect to github.com port 443: No route to host
[ERROR] An unexpected error occured:
'NoneType' object has no attribute 'decode'
Traceback (most recent call last):
  File "/home/pi/kiauh/kiauh/utils/git_utils.py", line 261, in git_cmd_pull
    run(command, cwd=target_dir, check=True)
  File "/usr/lib/python3.9/subprocess.py", line 528, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['git', 'pull']' returned non-zero exit status 1.
During handling of the above exception, another exception occurred:
  File "/home/pi/kiauh/kiauh/core/menus/base_menu.py", line 188, in run
    selected_option.method(
  File "/home/pi/kiauh/kiauh/core/menus/update_menu.py", line 175, in update_klipper
    update_klipper()
  File "/home/pi/kiauh/kiauh/components/klipper/klipper_setup.py", line 206, in update_klipper
    git_pull_wrapper(repo=settings.klipper.repo_url, target_dir=KLIPPER_DIR)
  File "/home/pi/kiauh/kiauh/utils/git_utils.py", line 66, in git_pull_wrapper
    git_cmd_pull(target_dir)
  File "/home/pi/kiauh/kiauh/utils/git_utils.py", line 263, in git_cmd_pull
    log = f"Error on git pull: {e.stderr.decode()}"
AttributeError: 'NoneType' object has no attribute 'decode'
du coup j'ai recontrôlé la MàJ de Raspbian et je me rends comptes que rien ne va plus :
Err:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf base-files armhf 11.1+rpi1+deb11u11
  Temporary failure resolving 'raspbian.raspberrypi.org'
Err:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libperl5.32 armhf 5.32.1-4+deb11u4
Err:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf perl armhf 5.32.1-4+deb11u4
49% [Connecting to raspbian.raspberrypi.org]
Err:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf perl-base armhf 5.32.1-4+deb11u4
Err:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf perl-modules-5.32 all 5.32.1-4+deb11u4
la  màj reste bloquée sur 49%
j'ai pris mon courage à deux mains et j'ai  refais mon Raspberry non sans avoir sauvegardé les fichiers.
Màj  Raspbian  ok
MàJ via Kiauh : NON
retour à la case départ impossible de MaJ klipper, Moonraker,crowsnest et Fluidd.
Je ne sais plus quoi faire
Modifié (le) par papagalak
Supprime le dépôt KIAUH installé ( ~/rm -rf kiauh ). Ré-installe KIAUH à partir du lien donné par @Kachidoki : https://github.com/dw-0/kiauh
Lors du démarrage de KIAUH, il est fort probable qu'il te demande quelle version utiliser (la 5 ou la 6). Dans un premier temps, je te conseille de rester sur la v5. La v5 utilise des scripts BASH tandis que la v6 utilise des scripts Python.
Un extrait du changelog :
Au démarrage, il vous sera demandé si vous souhaitez démarrer la nouvelle version 6 ou l'ancienne version 5. Tant que la version 6 est à l'état de pré-version, la version 5 sera toujours disponible.
  • 2 months later...
coucou me revoulou...
j'ai voulku installer Bed mesh adaptatif , natif klipper en suivant ce tuto:
Bed mesh adaptatif sur klipper
j'ai suivi la partie natif klipper en modifiant:
moonraker.conf
 printer.cfg
start_print
j'ai modifier dans OrcaSlicer : label objets
Résultat j'ai un palpage complet du plateau avant chaque impression
d'où vient mon erreur?
bon, j'ai trouvé mon erreur :
j'avais simplement oublié d'enlever la ligne : enable_object_processing: False
Maintenant ça marche avec bed mesh natif klipper.
A titre de curiosité:
est il possible de mettre en place des menus déroulant dans le panneau "Macros"
je m'explique :
regrouper tous les Gcodes "M..."
les "Preheat", Bed ect ...
car je trouve que cela prend de la place
certes on peut cacher à l'aide de la flèche
Il y a 3 heures, papagalak a dit :
À ma connaissance, non, mais je ne sais pas tout 😉.
On peut plus ou moins organiser les macros en les regroupant si c'est ce que tu cherches.
Fluidd a une documentation succincte à ce sujet, Mainsail est un peu plus prolixe :
  • 3 months later...
bonsoir, j'ai fais la boulette, je crois, j'ai voulu refaire le firmware de ma carte mère:
sur mon Raspberry :
je lance "make menuconfig" et voila ce qui ce passe
make[99]: Warning: File '/home/pi/klipper/.config' has modification time 272 s in the future
un défilé de plus de 1000 ligne repetant la même phrase.
et du coup impossible de faire "make menuconfig"
Ton RPi semble ne plus être à l'heure. Il n'y a pas de pile ni de CMOS pour maintenir date et heure correctes quand il n'est pas alimenté.
Normalement, après le démarrage, un daemon système devrait contacter un serveur de temps (NTP) pour mettre à jour date et heure. Mais pour que ça fonctionne, il faut une connexion internet fonctionnelle, l'est-elle ?
Si ce n'est pas une hypothèse correcte, alors, tu as peut-être une RPi capable de voyager dans le futur 😱 (modification time 272 s in the future).
Pas de pile, mon rpi est coupé complètement,.
Comment côntroler le bon fonctionnement  de la connexion internet, sachant que je suis derrière une freebox en rj45
Connecté en ssh sur la RPi, tu peux vérifier la date avec "timedatectl" :
mks@mkspi:~$ timedatectl
               Local time: mer. 2025-07-16 11:43:14 CEST
           Universal time: mer. 2025-07-16 09:43:14 UTC
                 RTC time: mer. 2025-07-16 09:43:10
                Time zone: Europe/Paris (CEST, +0200)
System clock synchronized: yes
              NTP service: active
          RTC in local TZ: no
Pour vérifier si la connexion internet fonctionne, un simple "ping -c4 www.free.fr" devrait te renvoyer (le paramètre -c4 n'envoie que 4 paquets, sans ce paramètre, les paquets sont envoyés en continu, pour arrêter un CTRL+C) :
mks@mkspi:~$ ping -c4 www.free.fr
PING www.free.fr (212.27.48.10): 56 data bytes
64 bytes from 212.27.48.10: icmp_seq=0 ttl=58 time=7,324 ms
64 bytes from 212.27.48.10: icmp_seq=1 ttl=58 time=7,761 ms
64 bytes from 212.27.48.10: icmp_seq=2 ttl=58 time=7,294 ms
64 bytes from 212.27.48.10: icmp_seq=3 ttl=58 time=7,648 ms
--- www.free.fr ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max/stddev = 7,294/7,507/7,761/0,202 ms
Il ne devrait normalement y avoir aucun paquet perdu 😉.
Modifié (le) par fran6p
@fran6p voici le retour:
pi@raspberrypi:~ $ timedatectl
               Local time: Fri 2025-05-09 00:26:27 CEST
           Universal time: Thu 2025-05-08 22:26:27 UTC
                 RTC time: n/a
System clock synchronized: no
              NTP service: active
          RTC in local TZ: no
pi@raspberrypi:~ $ ping -c4 www.free.fr
ping: www.free.fr: Temporary failure in name resolution
j'ai refait un test après avoir tapez:
sudo date --set '2025-07-16 16:28:00
même réponse
il y a 21 minutes, papagalak a dit :
là soit les dns, soit la connexion internet ne marchent pas.
un ifconfig te donnes quoi comme résultat ?
Modifié (le) par Savate
il y a 1 minute, Savate a dit :
pi@raspberrypi:~ $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether e4:5f:01:12:4c:3d  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 732  bytes 75934 (74.1 KiB)
        TX packets 732  bytes 75934 (74.1 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.191  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fd51:42f8:caae:d92e::ff  prefixlen 64  scopeid 0x0<global>
        inet6 2a01:e0a:21d:6520:227:9279:51c3:73f6  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::29a5:ea42:22fa:4a41  prefixlen 64  scopeid 0x20<link>
        ether e4:5f:01:12:4c:3e  txqueuelen 1000  (Ethernet)
        RX packets 271  bytes 28761 (28.0 KiB)
        TX packets 534  bytes 44128 (43.0 KiB)
il y a 4 minutes, papagalak a dit :
tu es connecté en wifi, pas en rj45 là.
pour taper les commandes tu es connecté en ssh (avec putty ou mobaterm ?)
il y a 9 minutes, Savate a dit :
je suis relié en rj45, mais d'après ce que tu me dit c'est le wifi qui est reconnu, peux etre un souci cable je change et je re essaie.
je travail sous putty
cable changer:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.190  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::4338:906a:37fe:3703  prefixlen 64  scopeid 0x20<link>
        inet6 2a01:e0a:21d:6520:93ac:5e9d:73c3:2b92  prefixlen 64  scopeid 0x0<global>
        RX packets 1253  bytes 81105 (79.2 KiB)
        TX packets 146  bytes 19100 (18.6 KiB)
        RX packets 64  bytes 6866 (6.7 KiB)
        TX packets 64  bytes 6866 (6.7 KiB)
        inet 192.168.0.77  netmask 255.255.255.0  broadcast 192.168.0.255
        RX packets 548  bytes 28861 (28.1 KiB)
        RX errors 0  dropped 1  overruns 0  frame 0
        TX packets 29  bytes 3857 (3.7 KiB)
je viens de retester make menuconfig et ça roule.
j'avais bien un blème sur mon rj45
merci à toi et @fran6p
il y a 14 minutes, papagalak a dit :
clairement, mais ça aurait du fonctionner en wifi quand même 🙂
il y a 5 minutes, Savate a dit :
Ben ça marcher pas, pas grave je me sert du wifi juste pour la caméra depuis mon salons.
il y a 1 minute, papagalak a dit :
après quand c'est possible même une mauvaise liaison RJ45 vaut mieux que tous les wifi du monde 🙂
  • Merci ! 2
