Il y a 1 heure, hyoti a dit :
Tout à la fin du printer.cfg,
j 'ai ça ...
Il y a 1 heure, Savate a dit :
fais voir la macro G32
quand je tape G32, la voron fait tout ça ... à lire de bas en haut ...
elle fait un Home XYZ, prends le klicky et nivelle le lit, repose le klicky, fit un nettoyage, un Z probe, puis ce place au milieu du plateau en attente.
18:51
probe: TRIGGERED
18:51
probe: TRIGGERED
18:51
Probe already docked
18:51
probe: TRIGGERED
18:51
Homing Z
18:51
probe: TRIGGERED
18:51
Retries: 1/5 Probed points range: 0.008438 tolerance: 0.020000
18:51
Making the following Z adjustments:
stepper_z = 0.013980
stepper_z1 = -0.010868
stepper_z2 = 0.002853
stepper_z3 = -0.005964
18:51
Average: 3.993215
18:51
Actuator Positions:
z: 3.979235 z1: 4.004083 z2: 3.990362 z3: 3.999179
18:51
Gantry-relative probe points:
0: 3.986768 1: 3.995205 2: 3.993955 3: 3.993955
18:51
probe at 250.000,25.000 is z=6.006670
18:51
probe at 250.000,25.000 is z=6.006045
18:51
probe at 250.000,25.000 is z=6.004170
18:51
probe at 250.000,225.000 is z=6.006357
18:51
probe at 250.000,225.000 is z=6.005732
18:50
probe at 250.000,225.000 is z=6.006045
18:50
probe at 50.000,225.000 is z=6.004795
18:50
probe at 50.000,225.000 is z=6.005420
18:50
18:50
probe at 50.000,25.000 is z=6.014170
18:50
probe at 50.000,25.000 is z=6.013232
18:50
probe at 50.000,25.000 is z=6.011045
18:50
Retries: 0/5 Probed points range: 0.259375 tolerance: 0.020000
18:50
stepper_z = -0.182295
stepper_z1 = -0.029285
stepper_z2 = 0.360598
stepper_z3 = -0.149018
18:50
Average: 4.004485
18:50
Actuator Positions:
z: 4.186780 z1: 4.033770 z2: 3.643887 z3: 4.153503
18:50
0: 4.142563 1: 4.012875 2: 3.883188 3: 4.102250
18:50
probe at 250.000,25.000 is z=5.898062
18:50
probe at 250.000,25.000 is z=5.897750
18:50
probe at 250.000,25.000 is z=5.896500
18:50
probe at 250.000,225.000 is z=6.116812
18:50
18:50
probe at 250.000,225.000 is z=6.116500
18:50
probe at 50.000,225.000 is z=5.987125
18:50
probe at 50.000,225.000 is z=5.987437
18:50
18:50
probe at 50.000,25.000 is z=5.858062
18:50
probe at 50.000,25.000 is z=5.857437
18:50
probe at 50.000,25.000 is z=5.853375
18:50
probe: open
18:50
Attaching Probe
18:50
probe: TRIGGERED
18:50
QG Level
18:50
probe: TRIGGERED
18:49
probe: TRIGGERED
18:49
probe: open
18:49
Homing Z
18:49
Homing Y
18:49
Homing X
18:49
X or Y not homed, forcing full G28
18:49
moving to a safe Z distance
18:49
No axis homed
18:49
G32
Modifié (le) par MP3
il y a 5 minutes, MP3 a dit :
dans le printer.cfg il doit y avoir le détail de la macro G32 (un klippy.log doit convenir aussi, les macros sont dedans)
Modifié (le) par Savate
il y a 37 minutes, Savate a dit :
dans le printer.cfg
il y a 3 minutes, MP3 a dit :
dans le printer.cfg
après la ligne
G28 Z
tu peux rajouter
BED_MESH_PROFILE LOAD=default
pour le forcer a recharger le nivellement (mais normalement c'est le cas)
on ne dois pas changer le nom "default", car moi j'avais enregistré sous "maillage_110deg", et je voulais faire 2 profils, un vers 110°C et l'autre vers 60°C par exemple.
Il y a 9 heures, MP3 a dit :
Dans ton printer config il y avait marqué default à la fin d'où la commande avec default.
Si tu l'as enregistré sous un autre nom, oui il faut mettre le bon nom 🙂
Il y a 7 heures, Savate a dit :
Arfff !!! je n'avais pas enregistré, maintenant c'est enregistré sous le nom désiré "maillage_110deg" et ça apparait dans le printer.cfg
par contre je n'arrive pas à faire mieux, j'ai re-vérifier les vis du bed sur les 2 rails, et les 2 rails sur le cadre, rien n'a changé. La plaque alu doit avoir cette forme !?
@hyoti
et entre 110°C et 60°C pas de différence notables !!! delta 0.192 et 0.193.
il y a une heure, MP3 a dit :
0,2 sur un plateau de 300mm c'est compliqué d'avoir mieux quand même 😄
Il ne faut pas oublier que la  forme est accentuée par le zoom.
il y a 22 minutes, Savate a dit :
Ok, je suis en train de me faire mes échelles de valeurs au fur et à mesure, il ne transpire pas grand chose à ce sujet sur le net.
Ok, on va laisser ainsi !
Je cogite sur modifier la tête d'impression,
en Stealthburner + CW2 ou Stealthburner + Orbiter V2 ou Dragonburner (j'ai les ventilos) + Orbiter V2 (j'ai l'orbiter V2)
reste à imprimer tout cela, mais ce serait quoi le mieux ?
Cohérent. Je laisse klipper charger le maillage par défaut que j'avais effectué à 108°.
Je n'y touche jamais.
J'ai 0.14 sur un plateau de 350mm alors que j'ai 0.95 sans la feuille magnétique et la plaque.
il y a 2 minutes, MP3 a dit :
J'ai ça en je n'en changerais pas.
il y a 33 minutes, Savate a dit :
ca doit générer du décalage de couches sur la hauteur, non ?
Ou le première couche compense en nivelant ?
il y a 48 minutes, MP3 a dit :
alors là, c'est un choix compliqué 😄
je n'utilise que des SB + CW2 ... et ils marchent très bien (et longtemps)
Le SB  + Orbiter ou SB + LGX Lite est bien côté (mais je n'ai pas testé ...)
Le dragon burner c'est si tu veux imprimer du maïs (aussi appelé PLA 🙂) très vite (grosse ventilation pièce) ... comme je n'imprime que de l'abs sur les vorons : aucun intérêt  pour moi 🙂 (et en plus il est moche 🙂)
il y a 46 minutes, MP3 a dit :
ça compense sur les premières couches, c'est invisible.
Si tu installes un SB ou un DB, et que tu veux passer en stealthchanger (multi tête) pense à prparer la partie stealth changer tant que tu y es : 2 avantages
* prêt pour le changeur de tête
* le Stealth chaner sert aussi de TAP et remplace très avantageusement le Klicky (qui est bien, mais incomparablement moins bien qu'un tap) 🙂
* avec le tap tu peux utiliser le bed mesh adaptatif (il scanne la zone à imprimer avant d'imprimer : un peu plus long mais plus jamais l'ombre d'un problème de première couche)
et oui ça fait 3 avantages et pas 2 🙂
Pour le stealth changer il faut des aimants 6x3 N52 (surtout pas sur ali express, ce ne sont pas des vrais N52 et ça pose des problèmes)
https://www.supermagnete.fr/
pour les autres pièces 'particulières' du stealth changer/tap celles là sont très bien
https://fr.aliexpress.com/item/1005004268781276.html (M4 12mm)
https://fr.aliexpress.com/item/1005006266401079.html (PCB Only)
https://fr.aliexpress.com/item/1005006197998526.html (4x6 H6)
il y a 55 minutes, Savate a dit :
Ok, ce sera donc SB + Orbiter V2, prêt pour multi tête.
@Funboard29
un lien pour l'impression des pièces SB + Orbiter V2 avec MGN12 ? ça doit être ça ... je regarde et en 3DF ?
Le 06/03/2025 at 13:04, Funboard29 a dit :
Tu as tout ce qu'il faut ICI pour l'Orbiter.
des aimants 6x3 N52
il ne semble pas y avoir d'aimants N52 en D6 sur ce site !
un lot de manchon 4x6 H6 (c-à-d 100 pièces)
un lot de goupilles M4*12 (c-à-d 20 pièces)
il y a 24 minutes, MP3 a dit :
il y en a tant que ça ? (dans la pratique il en faut 3) - j'en ai si tu veux, 5 ça passe sans soucis dans une enveloppe ...
il y a 30 minutes, MP3 a dit :
ça ça va il en faut 3 par tête (ça part vite).
oui il n'y en a plus ... donc fournisseur de secours :
Disc magnets / cylinders / round magnets made of neodymium in many sizes
le but est de faire entre 3 et 5 têtes ? donc il me faudrait 15 pièces ? c'est ça ?
qu'est ce qu'on récup de l'AB ? le ventilo ? ... ?
il y a 1 minute, MP3 a dit :
il n'y a qu'une seule pièce (qui reste fixe sur la gantry) qui utilise les manchons quel que soit le nombre de têtes donc il en faut 3 🙂 )
Pour les tétons par contre il en faut 3 par tête (donc les 12 = 4 têtes)
Aimants N52 en D6 ép 3mm (3 par tête) lien
un lot de manchon 4x6 H6 (3 pièces) lien
un lot de goupilles M4*12 (3 par tête) lien
PCB only lien
J'ai déjà ça en impression :
stealthburner_body ==> ok
toolhead_front ==> ok
toolhead_rear ==> ok
pour le reste pas sûr
Aimants N52 en D6 ép 3mm, combien par tête ?
3 pour la partie fixe + 1 pour chaque tête (mais eux tu peux en prendre en rab, ça sert de partout)
Bill of Materials · DraftShift/StealthChanger Wiki · GitHub
il y a 41 minutes, Savate a dit :
donc 3 pour la partie fixe et 4 par tête ?
c'est quoi ce lien ?
A commander :
PCB only lien
==> stealthburner_body
==> toolhead_front
==> toolhead_rear
à imprimer :
==> x_carriage_frame_right (le mien est ré-usiné pour le besoin, à remplacer)
==> x_carriage_frame_left (le mien est ré-usiné pour le besoin, à remplacer)
il y a 6 minutes, MP3 a dit :
non il n'y a qu'une seule partie fixe (le chariot) quel que soit le nombre de têtes, donc 3 pour la partie fixe
et 1 seul par tête
les lien du github du stealthchanger  et de sa bom (bill of materials)
DB semble moins massif que SB, quand est-il du poids, ce n'est pas un critère de vitesse et de vibration ?
moins massif, mais apparemment compliqué pour la maintenance.
3 ventilos donc plus de vibrations.
si tu veux gagner du poids, met une hotend bambulabs : ça ne pèse rien, ça a un très bon débit, ça monte en t° à la vitesse de l'éclair et ce n'est pas cher du tout par rapport au tarif astronomique d'une dragon 🙂
Le 13/03/2025 at 15:07, Funboard29 a dit :
Ecris trop vite, il faut lire 0.09 sans la feuille.
il y a 18 minutes, Funboard29 a dit :
wouai, les tolérances s'ajoutent ...+ ... + ... +
Etonnant qu'il n'a pas été prévu un moyen de compenser, style serrage en 5 ou 6 points glissant !
Ca existe mais le problème est d'avoir une base de fixation plus rigide que la plaque, ce n'est pas évident avec 8mm d'épaisseur.
Avec à la clé de gros problèmes de dilatation.
J'avais commencé à rectifier la mienne sur un marbre.
Lorsque j'ai vu les différences d'épaisseur de l'ensemble aimant/plaque, plus de 4/100e, j'ai arrêté.
J'ai un peu moins avec le matériel de chez Energetic mais c'est pas parfait.
Modifié (le) par Funboard29
