+1 avec @Maeke, j'ai essayé de faire un truc easy pour que tout le monde puisse refaire les prints en fonction de leurs version d'anet.
pour le lien je ne sais plus ,j en est tellement telechargerque j ai du mal a mis retrouver , je peint a l aerographe et au pinceau ,j ai des tas de marque de peinture que de la crylique a l eau et alcool,avec sous couche mastic en bombe et apres en bombe.colle cyanochrilate ,eraldite ou a bois.j essais tous se que je trouve.cdlt
le lien est souvent marqué en toutes lettres dans le fichier texte se trouvant dans l'archive du fichier stl.
Le readme.txt
pour exemple:
https://www.thingiverse.com/thing:1919544
Anet A8 X-Carriage Mounts by Leo_N is licensed under the Creative Commons - Attribution - Non-Commercial license.
http://creativecommons.org/licenses/by-nc/3.0/
# Summary
I designed these X-carriages to fit my needs. They are, for the most part, the same as the original carriages that came with the kit.
The major reason in creating these was to ensure the correct distance between the two ilders in relation to the guided rods.
Assembly instructions:
- Make sure both X-guide rods are 436mm in length.
- For easier insertion I recommend burring the end of the 436mm guide rods first. This makes it easier to insert them into the idlers.
- Due to tolerances in the print I also recommend using an 8mm drill to smooth the holes on the carriage. Only one careful pass is necessary. The rods must still fit snugly!
- Insert the 2 rods in the left carriage until they reach the end.
- Mount the completely assembled extruder to the guided X-rods.
- Carefully mount the right carriage to the guide rods until it reaches the end.
- Now you can mount the whole extruder assembly with carriages and X-guide rods to the Z-guide rods.
I've also included an X-carriage tensioner. I thought this solution was a great idea to tension the belt : http://www.thingiverse.com/thing:1683070
You will need 2 x M3x25mm screws and 2 x M3 nuts to mount the tensioner to the right carriage.
The disc is for straightening the threaded shaft should it be off center and doesn't freely go through the top frame hole. To make corrections you will need to sand the disc to the appropriate angle for correct fit.
I also recommend that the linear bearing be positioned in the center of the carriage. For this I created a bolt tool that can be used to push the bearing all the way in until the bolt tool is even with the carriage surface.
These carriages are not a must have. Print them out if want to do some small improvements.
Please let me know if you have a problem with the design so I can improve it if necessary.
Also please post a picture with comments if you have made one.
Thanks.
Leo
<B>Update 21.1.2017:</B>
I've added a second version of the left motor carriage. It now has a channel for the X-stop cable.
<B>Update 25.1.2017:</B>
Version 1.1 of both carriages. The X-stop switch has been re-positioned making it easier to lay the cable behind the carriage. Some small modifications were also made.
<B>Update 18.4.2017:</B>
Uploaded "X_Idler_Right_Tensioner-9.4_Leo_N" to accommodate GT2-16 pulley.
<B>Update 24.5.2017:</B>
Uploaded "X_Idler_Right_Tensioner-9.0_Leo_N" to accommodate GT2-16 pulley for well calibrated printers.
<B>Update 7.6.2017:</B>
Uploaded "X_Idler_Right_Tensioner-11.4_Leo_N" to accommodate GT2-16/20 pulley (11mm wide) for 6mm belts.
# Print Settings
Printer: Anet A8
Rafts: Doesn't Matter
Supports: No
Resolution: 0.28
Infill: 25%
Notes:
Print speed 35mm/s with a 1.2mm shell thickness and 1.2mm top / bottom thick closures.
For the Disc and the Bolt Tool use 100% infill!
C'est du W.I.P. mais ça rox le pâté
Modèle d'Anet :   Anet A8                      Type & modèle de l'extrudeur : Stock
Filament : PLA noir                De chez : Geeetech
Température d'impression : 205°C les premières couches  puis 175/180°C     Lit : 60°C         Hauteur de couche : 0.1
Surface d'impression :  Buildtak Eewolf      Support : yep + raft pour les épaules+le buste
Slicer : Cura  3.4.1
Lien du fichier :  https://www.thingiverse.com/thing:3161348
Le noir est vraiment chiant a prendre en photo, quand elle sera en couleurs ça devrait aller mieux
  • J'aime 4
il y a 39 minutes, Andréa a dit :
.. /.. C'est du W.I.P. mais ça rox le pâté
Ah lala, heureusement qu'on a Internet pour décoder ces machins de djeun's...
Vive la langue vivante et son évolution, après tout on a bien un miniss' qui nous a sorti le mot "croisser".... Bin, oui, la croissance, ça donne "croisser"
Chuis sûr que ça va plaire à mes vieux cons plisses ( @Janpolanton @rmlc460 @fran6p @Chevelu37  @Desmojack @.AleX.)
  • Haha 3
il y a 17 minutes, Jean-Claude Garnier a dit :
bon bah moi, je ne fais définitivement plus partie des jeunes irréfléchis, et apparemment je ne suis pas encore compté dans les vieux cons, serait-ce l'âge de l'intelligence?
Modifié (le) par Maeke
Il y a 2 heures, Andréa a dit :
Je vais allé déterré le vieux français ^^
c'est pas du vieux français, c'est du vrai français.
Le vieux français c'est celui du moyen-âge, aucun des vieux n'est capable de le parler couramment.
Il y a 13 heures, Andréa a dit :
Surface d'impression :  Buildtak Eewolf      Support : yep + raft pour les épaules+le busteimageproxy.php?img=&key=5f3e5f9bb3c90432
Slicer : Cura  3.4.1
Diantre ça rox de ouf !
Vivement que cette gourgandine fusse terminois que ça nous deboitasse les yeux ma gueule !
  • Haha 3
il y a 28 minutes, reeb a dit :
raté, c'est pas du vieux français, c'est un mélange.
Donc Maeke, étant de 10 ans ton aîné, aurais-je dépassé l'âge de l'intelligence ? Mais non, pas encore un vieux con 😁, j'ai juste arrêté de croisser....
Modifié (le) par thierry70
il y a 39 minutes, thierry70 a dit :
Non, pas encore un vieux con, mais s'approchant de l'âge de la sagesse.
Il y a 9 heures, Andréa a dit :
Depuis quand Ribéry est ministre ?
Non, ce n'était pas lui mais un ancien ministre socialiste (espèce en voie de disparition comme un bon nombre d'autres d'ailleurs (en cause le réchauffement climatique ?)) ancien maire d'une ville proche de celle où je réside, ancien président de la Région où se situent ces deux villes, dont le nom patronymique est de la famille des conifères.
Comme JCG, je préfère que notre belle langue ne soit pas trop malmenée même si elle doit évidemment continuer à évoluer. Je trouve que nos cousins québécois ont une meilleure approche que nous qui avons trop tendance à utiliser des termes anglo-saxons car ça fait bien et donne l'impression d'être à la page, d'être moderne 😉
il y a 12 minutes, fran6p a dit :
n'empêche que je vais avoir du mal à utiliser nonante dans la vie de tous les jours.
Oui @Andréa... le conifère de Noël, pas le foutchebôleur Frank(enstein)
Oué oué moi j'aime bien que la langue évolue. Un peu. Ce que je n'aime pas surtout, c'est la disparition de l'accord du participe passé.
ça, j'avoue que ça me pique les yeux, mais alors grave : j'ai acheter un mosfet, tu as griller ta carte, il a imprimer un machin.... AU SECOURS !
Le français est une langue vivante... Donc elle vie et c'est tant mieux.. Sinon on parlerai encore le latin.. 🤤🤤🤤
Tu quoque mi imprimantae anet a8
il y a 7 minutes, reeb a dit :
vivante je veux bien, mais si on laisse faire elle va plutôt dégénérer.
Sinon pourrait-on retourner au sujet de base ? Où faut que je ressorts des expressions über top moumoute ? 😂
Direction Mars !
Modèle d'Anet :  A8                                        Type & modèle de l'extrudeur : de base
Filament :        PLA                                          De chez : Repraper
Température d'impression :   190               Lit : 60
Surface d'impression :     scotch + fixatif                       Support : non
Slicer : Slic3r
Post traitement : Poncage , XTC3D, bombe acrylique et peinture citadel
Lien du fichier : https://www.thingiverse.com/thing:2895356
Et en plus ca brille ...
Slicer : Slic3r
Caracteristique d'impression : 0.1mm, 0% infill, 35mm/s
Post traitement : Ajout d'un système d'éclairage à base de bougie led
Lien du fichier : https://www.thingiverse.com/thing:1912559
